Introdução
This guide will narrate the process of simultaneously removing a defective keyboard and touchpad panel. These components are both attached to the internal base panel and cannot be removed separately. Removing this panel is also the first step to accessing other internal components.
O que você precisa
Turn the laptop over.
Remove all nine 3mm screws on back panel with a Phillips Head 1 driver.
While keeping silver keyboard panel hovering above the laptop, locate the touchpad connector ribbon attached to both the silver panel and motherboard.
With your finger, flip up the white clasp that holds the connector, releasing the connector ribbon.
Unpeel the connector ribbon from its position on the motherboard.
To reassemble your device, follow these instructions in reverse order. Remember to carefully handle and replace the blue and silver connectors.
