Ir para o conteúdo principal
HP Pavilion 14-b120dx Wireless Card Replacement
O que você precisa
  1. HP Pavilion 14-b120dx Wireless Card Replacement, Battery: passo 1, imagem 1 %32
    • Power down the laptop and detach the charging cord (failure to do so can result in electrical shock).
  2. HP Pavilion 14-b120dx Wireless Card Replacement: passo 2, imagem 1 %32 HP Pavilion 14-b120dx Wireless Card Replacement: passo 2, imagem 2 %32 HP Pavilion 14-b120dx Wireless Card Replacement: passo 2, imagem 3 %32
    • Flip the laptop upside down so that the bottom is facing you.
    • Push the slide on the right toward the center of the laptop, releasing the battery latch.
    • Lift the battery up and away from the laptop.
  3. HP Pavilion 14-b120dx Wireless Card Replacement, Keyboard: passo 3, imagem 1 %32 HP Pavilion 14-b120dx Wireless Card Replacement, Keyboard: passo 3, imagem 2 %32 HP Pavilion 14-b120dx Wireless Card Replacement, Keyboard: passo 3, imagem 3 %32
    • Insert the plastic opening tool between the keyboard and the palm rest.
    • Pry upwards until the keyboard section detaches from the laptop.
    • Repeat this around the edge of the entire keyboard.
    • Sections will make loud snapping noises as they detach from the palm rest - this is normal.
  4. HP Pavilion 14-b120dx Wireless Card Replacement: passo 4, imagem 1 %32 HP Pavilion 14-b120dx Wireless Card Replacement: passo 4, imagem 2 %32
    • Lift the keyboard slowly up until the connecting cable is exposed.
    • Carefully lift the flap on the ZIF connector using a fingernail or plastic opening tool. This will release the cable.
    • Detach the cable.
  5. HP Pavilion 14-b120dx Wireless Card Replacement, Palm Rest: passo 5, imagem 1 %32 HP Pavilion 14-b120dx Wireless Card Replacement, Palm Rest: passo 5, imagem 2 %32
    • Unscrew the 10 6.0 mm screws under the keyboard housing with a Philips #0 head screwdriver.
  6. HP Pavilion 14-b120dx Wireless Card Replacement: passo 6, imagem 1 %32 HP Pavilion 14-b120dx Wireless Card Replacement: passo 6, imagem 2 %32 HP Pavilion 14-b120dx Wireless Card Replacement: passo 6, imagem 3 %32
    • Insert the plastic opening tool into the seam between the palm rest and the laptop.
    • Pry upwards until the palm rest separates from the laptop.
    • Repeat this process around the entire computer.
    • These steps will be similar to the ones you took to remove the keyboard. Again, you will hear snapping noises.
  7. HP Pavilion 14-b120dx Wireless Card Replacement: passo 7, imagem 1 %32
    • Lift upwards to remove the palm rest.
  8. HP Pavilion 14-b120dx Wireless Card Replacement, Wireless Card: passo 8, imagem 1 %32 HP Pavilion 14-b120dx Wireless Card Replacement, Wireless Card: passo 8, imagem 2 %32
    • Remove the two 4.0 mm screws using a Philips #00 head screwdriver.
  9. HP Pavilion 14-b120dx Wireless Card Replacement: passo 9, imagem 1 %32 HP Pavilion 14-b120dx Wireless Card Replacement: passo 9, imagem 2 %32
    • Detach the two wires connecting to the motherboard to the wireless card.
  10. HP Pavilion 14-b120dx Wireless Card Replacement: passo 10, imagem 1 %32 HP Pavilion 14-b120dx Wireless Card Replacement: passo 10, imagem 2 %32
    • Slide the card upwards and outwards to detach it from the motherboard.
Conclusão
Uma outra pessoa concluiu este guia.
Erin Lavalla
Membro desde: 10/18/16
458 Reputação
Autoria de 4 guias
Equipe
UMass Dartmouth, Team 4-4, Catania Fall 2016 Membro de UMass Dartmouth, Team 4-4, Catania Fall 2016
UMASSD-CATANIA-F16S4G4
Membros da 3
Autoria de 6 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 4
Últimos 30 dias: 9
Duração total: 531
