Introdução
In this guide, you will find helpful information on removing and replacing the Wi-Fi card in an HP Pavilion 14-b015dx laptop.
Signs of a defective Wi-Fi card include not showing available Wi-Fi networks, frequently dropped Wi-Fi connections, and slow network speeds. As connection issues may arise from network problems, it is a good idea to test the laptop on different Wi-Fi networks to diagnose this problem correctly.
This guide requires the removal of the keyboard and the top case of the laptop. Before starting this process, the laptop must be unplugged and powered off completely.
O que você precisa
Unscrew the ten 6.0 mm Philips head screws on the base of the device with a Phillips #0 head screwdriver.
Remove the eight 6.0 mm screws located under the keyboard with your Philips #0 screwdriver.
Remove the two 4.0 mm long screws on the corners of the wireless card the using a Philips #0 screwdriver.
