Ir para o conteúdo principal
HP Pavilion 14-b015dx Palm Rest Replacement
O que você precisa
  1. HP Pavilion 14-b015dx Palm Rest Replacement, Battery: passo 1, imagem 1 %32
    • Make sure the computer is completely powered down and unplug the power cord.
  2. HP Pavilion 14-b015dx Palm Rest Replacement: passo 2, imagem 1 %32
    • Place the device on your work surface with bottom facing up and the battery located at the top.
  3. HP Pavilion 14-b015dx Palm Rest Replacement: passo 3, imagem 1 %32
    • Slide the left release tab toward the center of the computer to the unlock position. Next slid the right tab toward the center of the computer and hold it there while completing step 4.
  4. HP Pavilion 14-b015dx Palm Rest Replacement: passo 4, imagem 1 %32
    • Remove the battery by sliding it upwards and away from the computer.
  5. HP Pavilion 14-b015dx Palm Rest Replacement, Keyboard: passo 5, imagem 1 %32
    • Unscrew the ten 6.0 mm Philips head screws on the base of the device with a Phillips #0 head screwdriver.
  6. HP Pavilion 14-b015dx Palm Rest Replacement: passo 6, imagem 1 %32
    • Insert the plastic opening tool between the keyboard and the plastic housing.
    • Pry the keyboard upward away from the device.
    • Move the tool around the edge of the entire keyboard while continuing to pry.
    • You will hear the clips pop once you have released them.
  7. HP Pavilion 14-b015dx Palm Rest Replacement: passo 7, imagem 1 %32
    • Once you have released all of the clips, slowly lift the keyboard exposing the ribbon cable.
    • Lift the tab on the keyboard ZIF connector with a plastic opening tool and gently remove the ribbon cable.
  8. HP Pavilion 14-b015dx Palm Rest Replacement, Palm Rest: passo 8, imagem 1 %32
    • Remove the eight 6.0 mm screws located under the keyboard with your Philips #0 screwdriver.
  9. HP Pavilion 14-b015dx Palm Rest Replacement: passo 9, imagem 1 %32
    • Remove the track pad and power button ribbon cables.
    • Lift the locking bar on each connector with a plastic opening tool and gently remove the ribbon cables
  10. HP Pavilion 14-b015dx Palm Rest Replacement: passo 10, imagem 1 %32
    • To remove the palm rest, insert the plastic opening tool in the seam between the palm rest and the base.
    • Pry upward to undo each clip.
    • Continue this process around the entire palm rest.
  11. HP Pavilion 14-b015dx Palm Rest Replacement: passo 11, imagem 1 %32
    • Once all clips have been undone lift the palm rest away from the laptop.
Conclusão
Gregory Bridge
Membro desde: 10/24/17
623 Reputação
Autoria de 6 guias
Equipe
UMass Dartmouth, Team S1-G1, Isaacson Fall 2017 Membro de UMass Dartmouth, Team S1-G1, Isaacson Fall 2017
UMASSD-ISAACSON-F17S1G1
Membros da 3
Autoria de 6 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 5
Duração total: 354
