Ir para o conteúdo principal
HP Pavilion 14 hard drive
O que você precisa
  1. HP Pavilion 14 hard drive, Keyboard & Touchpad Panel: passo 1, imagem 1 %32 HP Pavilion 14 hard drive, Keyboard & Touchpad Panel: passo 1, imagem 2 %32
    • Turn the laptop over.
    • Remove all nine 3mm screws on back panel with a Phillips Head 1 driver.
  2. HP Pavilion 14 hard drive: passo 2, imagem 1 %32 HP Pavilion 14 hard drive: passo 2, imagem 2 %32 HP Pavilion 14 hard drive: passo 2, imagem 3 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Pry off the four rubber bumpers, located at the top corners and center of the back panel, off with a pair of tweezers.
    • Bumpers are delicate and can be easily ripped.
    • Unscrew the four 3mm screws under the bumpers using a Phillips Head 1 screwdriver.
  3. HP Pavilion 14 hard drive: passo 3, imagem 1 %32 HP Pavilion 14 hard drive: passo 3, imagem 2 %32
    • Flip the laptop right side up and open the clamshell.
    • Starting at the bottom right corner, slide the opening tool into the crevice between the blue and silver panels.
    • Carefully pry the top casing up around the edges, moving counterclockwise.
    • Keep the tool steady throughout, as prying in a rough manner can break the casing.
    • You will hear audible clicking sounds as the clips connecting the two halves disconnect from each other.
  4. HP Pavilion 14 hard drive: passo 4, imagem 1 %32
    • Close the laptop and orient it on its side (clamshell hinge up), carefully holding it steady to ensure its safety.
    • Insert the opening tool inside of the hinge and pry with an even amount of force to disconnect the keyboard panel from the fan grate.
  5. HP Pavilion 14 hard drive: passo 5, imagem 1 %32 HP Pavilion 14 hard drive: passo 5, imagem 2 %32 HP Pavilion 14 hard drive: passo 5, imagem 3 %32
    • Reorient the laptop in an upright fashion and open the clamshell.
    • If needed, continue to pry the silver keyboard panel from the rest of the hardware with minimal force.
    • Slowly slide the silver keyboard panel towards you while lifting gently to separate the halves.
    • The panel is still connected by a series of delicate connectors glued to the mainframe, so do not pull the panel right off.
  6. HP Pavilion 14 hard drive: passo 6, imagem 1 %32 HP Pavilion 14 hard drive: passo 6, imagem 2 %32 HP Pavilion 14 hard drive: passo 6, imagem 3 %32
    • While keeping silver keyboard panel hovering above the laptop, locate the touchpad connector ribbon attached to both the silver panel and motherboard.
    • With your finger, flip up the white clasp that holds the connector, releasing the connector ribbon.
    • Unpeel the connector ribbon from its position on the motherboard.
  7. HP Pavilion 14 hard drive: passo 7, imagem 1 %32 HP Pavilion 14 hard drive: passo 7, imagem 2 %32 HP Pavilion 14 hard drive: passo 7, imagem 3 %32
    • With your finger, flip up the white clasp that connects the larger keyboard connector to the motherboard, releasing the connector ribbon.
    • Gently pull the connector ribbon from the clasp.
  8. HP Pavilion 14 hard drive: passo 8, imagem 1 %32
    • Lift the keyboard panel up and away from the CPU, completely revealing the mainframe.
  9. HP Pavilion 14 hard drive, Battery and Speakers: passo 9, imagem 1 %32
    • With the internal hardware exposed, disconnect the battery cable from the motherboard.
    • If tightly fastened, gently wiggle the plug out of the jack.
  10. HP Pavilion 14 hard drive: passo 10, imagem 1 %32
    • Remove the three 4mm screws around the perimeter of the battery pack with a Phillips Head 1 screwdriver.
  11. HP Pavilion 14 hard drive: passo 11, imagem 1 %32 HP Pavilion 14 hard drive: passo 11, imagem 2 %32 HP Pavilion 14 hard drive: passo 11, imagem 3 %32
    • Flip up the two white clasps that hold the connector ribbon to the battery to release the ribbon.
    • Remove the 'motherboard to USB board' connector ribbon from its place.
  12. HP Pavilion 14 hard drive: passo 12, imagem 1 %32
    • Detach the speaker cable from its fastener on the motherboard by pulling it out with your fingers or using a spudger.
  13. HP Pavilion 14 hard drive: passo 13, imagem 1 %32 HP Pavilion 14 hard drive: passo 13, imagem 2 %32 HP Pavilion 14 hard drive: passo 13, imagem 3 %32
    • Using your fingers, gently pry out the two L-shaped speaker panels from between the external casing and battery pack.
    • Be sure to apply an evenly distributed upwards force on the speaker when lifting it out
    • Both speaker components (located adjacent to each other) will remain connected by a red cable after removal
  14. HP Pavilion 14 hard drive: passo 14, imagem 1 %32
    • Lift out battery pack.
  15. HP Pavilion 14 hard drive, Motherboard: passo 15, imagem 1 %32 HP Pavilion 14 hard drive, Motherboard: passo 15, imagem 2 %32
    • Remove the two Wi-Fi antenna cables that are attached to the Wi-Fi card by pulling them up.
  16. HP Pavilion 14 hard drive: passo 16, imagem 1 %32
    • Using your fingers, pull the cooling fan cable from its fastener on the motherboard
  17. HP Pavilion 14 hard drive: passo 17, imagem 1 %32
    • Remove the 3mm screw that holds down the Wifi mini-PCI card using a Phillips Head 1 driver.
  18. HP Pavilion 14 hard drive: passo 18, imagem 1 %32
    • Remove the three 3mm screws that hold the cooling fan in place using a Phillips Head 1 driver.
  19. HP Pavilion 14 hard drive: passo 19, imagem 1 %32
    • In the upper right hand corner of the device, remove the 6mm screw holding the PCB board in place by using a Phillips Head 1.
  20. HP Pavilion 14 hard drive: passo 20, imagem 1 %32 HP Pavilion 14 hard drive: passo 20, imagem 2 %32 HP Pavilion 14 hard drive: passo 20, imagem 3 %32
    • Remove the three 3mm screws from the surface of the motherboard using a Phillips Head 1.
  21. HP Pavilion 14 hard drive: passo 21, imagem 1 %32 HP Pavilion 14 hard drive: passo 21, imagem 2 %32
    • Carefully lift the motherboard up towards the screen as if it was hinged on one side.
    • To prevent possible scratching, cover the screen with a cloth.
  22. HP Pavilion 14 hard drive, HP Pavilion 14 hard drive: passo 22, imagem 1 %32
    • Remove the 3mm screw located directly above the NGFF SSD card using a Phillips Head 1 driver.
  23. HP Pavilion 14 hard drive: passo 23, imagem 1 %32 HP Pavilion 14 hard drive: passo 23, imagem 2 %32
    Comprar
    • Pull the SSD card up and out using your fingers.
    • Do not use tweezers or any other metal tool to extract the card, as it is fragile.
Conclusão
Danica Dunville
Membro desde: 09/11/17
349 Reputação
Autoria de 3 guias
Equipe
CSU Fullerton, Team S2-G2, Bruce Fall 2017 Membro de CSU Fullerton, Team S2-G2, Bruce Fall 2017
CSUF-BRUCE-F17S2G2
Membros da 3
Autoria de 6 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 14
Últimos 30 dias: 76
Duração total: 4,847
