Ir para o conteúdo principal
HP Pavilion 11-n010dx Ram Replacement
O que você precisa
  1. HP Pavilion 11-n010dx Ram Replacement, Battery: passo 1, imagem 1 %32 HP Pavilion 11-n010dx Ram Replacement, Battery: passo 1, imagem 2 %32
    • Use the nylon spudger to remove the rubber pads near the hinge of the screen, then remove the screws under the pads.
    • Use the Phillips #0 to remove four 9mm screws.
    • Use the Phillips #0 to remove seven 6mm screws.
  2. HP Pavilion 11-n010dx Ram Replacement: passo 2, imagem 1 %32 HP Pavilion 11-n010dx Ram Replacement: passo 2, imagem 2 %32 HP Pavilion 11-n010dx Ram Replacement: passo 2, imagem 3 %32
    • Use the nylon spudger to pry the back casing near the hinges for the screen.
    • Continue to pry along the edge of the back case until the back is ready to be removed.
    • Careful when beginning to remove the case. There is a cable attached between the bottom case and the motherboard that must be properly disconnected.
  3. HP Pavilion 11-n010dx Ram Replacement: passo 3, imagem 1 %32 HP Pavilion 11-n010dx Ram Replacement: passo 3, imagem 2 %32
    • Use the blue plastic opening tool to lift up on the white tab that is holding the cable in place on the motherboard.
    • Now carefully pull the cable out of place and remove the entire back casing.
  4. HP Pavilion 11-n010dx Ram Replacement: passo 4, imagem 1 %32
    • Remove the five 6mm screws that hold the battery in place using the Phillips #0.
  5. HP Pavilion 11-n010dx Ram Replacement: passo 5, imagem 1 %32 HP Pavilion 11-n010dx Ram Replacement: passo 5, imagem 2 %32
    • Use the nylon spudger to pry away the blue/white wire that is positioned near your battery.
  6. HP Pavilion 11-n010dx Ram Replacement: passo 6, imagem 1 %32 HP Pavilion 11-n010dx Ram Replacement: passo 6, imagem 2 %32
    • Disconnect the battery cable from the motherboard by carefully pulling on the black wire at the point closest to the white tab.
  7. HP Pavilion 11-n010dx Ram Replacement: passo 7, imagem 1 %32
    • Remove the battery from your device.
  8. HP Pavilion 11-n010dx Ram Replacement, Ram: passo 8, imagem 1 %32 HP Pavilion 11-n010dx Ram Replacement, Ram: passo 8, imagem 2 %32
    • Using your fingernails, pull the tabs on either side of the RAM to release the module from its secured spot.
  9. HP Pavilion 11-n010dx Ram Replacement: passo 9, imagem 1 %32 HP Pavilion 11-n010dx Ram Replacement: passo 9, imagem 2 %32
    • Carefully grab and pull to remove the RAM from your device.
Conclusão
Uma outra pessoa concluiu este guia.
Joseph Lintz
Membro desde: 09/15/16
915 Reputação
Autoria de 5 guias
Equipe
USF Tampa, Team 11-5, Blackwell Fall 2016 Membro de USF Tampa, Team 11-5, Blackwell Fall 2016
USFT-BLACKWELL-F16S11G5
Membros da 3
Autoria de 5 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 5
Últimos 30 dias: 21
Duração total: 751
