Introdução
If the bottom case of your device become cracked or damaged, this guide will show you how to replace it.
O que você precisa
Use the nylon spudger to remove the rubber pads near the hinge for the screen. Then remove the screws under the pads.
Use Phillips #0 to remove four 9mm screws.
Use Phillips #0 to remove seven 6mm screws.
Uma outra pessoa concluiu este guia.
