Ir para o conteúdo principal
HP Pavilion 11 x360 Speakers Replacement
O que você precisa
  1. HP Pavilion 11 x360 Speakers Replacement, Remove Screws: passo 1, imagem 1 %32 HP Pavilion 11 x360 Speakers Replacement, Remove Screws: passo 1, imagem 2 %32
    • Use the spudger to pry off the two rubber feet near the hinge of the laptop. This will reveal two hidden 9mm screws.
    • You must remove eleven screws.
    • Four 9mm screws with the PH0 screwdriver.
    • Seven 6mm screws with the PH0 screwdriver.
  2. HP Pavilion 11 x360 Speakers Replacement, Remove Backing: passo 2, imagem 1 %32 HP Pavilion 11 x360 Speakers Replacement, Remove Backing: passo 2, imagem 2 %32 HP Pavilion 11 x360 Speakers Replacement, Remove Backing: passo 2, imagem 3 %32
    • Use the spudger to pry the corners of the laptop near the display hinges.
    • Pry around the seam of the laptop with the plastic opening tool until the backing begins to pull apart.
    • When you lift the bottom cover, there is a cable connected between the motherboard and the bottom cover. Be careful not to pull the cable loose!
  3. HP Pavilion 11 x360 Speakers Replacement, Detach Cable: passo 3, imagem 1 %32 HP Pavilion 11 x360 Speakers Replacement, Detach Cable: passo 3, imagem 2 %32
    • Use the plastic opening tool to lift the white tab up at the connection.
    • Pull the cable outwards.
  4. HP Pavilion 11 x360 Speakers Replacement, Battery: passo 4, imagem 1 %32
    • Remove the four 6mm screws from the battery with the PH0 screwdriver.
  5. HP Pavilion 11 x360 Speakers Replacement: passo 5, imagem 1 %32 HP Pavilion 11 x360 Speakers Replacement: passo 5, imagem 2 %32 HP Pavilion 11 x360 Speakers Replacement: passo 5, imagem 3 %32
    • Use the spudger to pry up the blue/white speaker wires that are routed beside the battery.
  6. HP Pavilion 11 x360 Speakers Replacement: passo 6, imagem 1 %32 HP Pavilion 11 x360 Speakers Replacement: passo 6, imagem 2 %32
    • Remove the battery cable from the motherboard by gently pulling out on the black part of the cable closest to the white tab.
  7. HP Pavilion 11 x360 Speakers Replacement: passo 7, imagem 1 %32 HP Pavilion 11 x360 Speakers Replacement: passo 7, imagem 2 %32
    • Remove the battery.
  8. HP Pavilion 11 x360 Speakers Replacement, Speakers: passo 8, imagem 1 %32 HP Pavilion 11 x360 Speakers Replacement, Speakers: passo 8, imagem 2 %32 HP Pavilion 11 x360 Speakers Replacement, Speakers: passo 8, imagem 3 %32
    • Remove two 6mm screws on each speaker with the PH0 screwdriver.
  9. HP Pavilion 11 x360 Speakers Replacement: passo 9, imagem 1 %32 HP Pavilion 11 x360 Speakers Replacement: passo 9, imagem 2 %32 HP Pavilion 11 x360 Speakers Replacement: passo 9, imagem 3 %32
    • Disconnect the black cable that attaches the speakers to the motherboard by gently pulling the cable outward.
    • Remove the speakers.
Conclusão
Natalie
Membro desde: 01/22/15
937 Reputação
Autoria de 4 guias
Equipe
Cal Poly, Team 19-9, Maness Winter 2015 Membro de Cal Poly, Team 19-9, Maness Winter 2015
CPSU-MANESS-W15S19G9
4 Membros
Autoria de 12 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 3
Últimos 7 dias: 8
Últimos 30 dias: 28
Ao todo: 1,731
