Ir para o conteúdo principal
HP Pavilion 11 x360 Motherboard Replacement
O que você precisa
  1. HP Pavilion 11 x360 Motherboard Replacement, Remove Screws: passo 1, imagem 1 %32 HP Pavilion 11 x360 Motherboard Replacement, Remove Screws: passo 1, imagem 2 %32
    • Use the spudger to pry off the two rubber feet near the hinge of the laptop. This will reveal two hidden 9mm screws.
    • You must remove eleven screws.
    • Four 9mm screws with the PH0 screwdriver.
    • Seven 6mm screws with the PH0 screwdriver.
  2. HP Pavilion 11 x360 Motherboard Replacement, Remove Backing: passo 2, imagem 1 %32 HP Pavilion 11 x360 Motherboard Replacement, Remove Backing: passo 2, imagem 2 %32 HP Pavilion 11 x360 Motherboard Replacement, Remove Backing: passo 2, imagem 3 %32
    • Use the spudger to pry the corners of the laptop near the display hinges.
    • Pry around the seam of the laptop with the plastic opening tool until the backing begins to pull apart.
    • When you lift the bottom cover, there is a cable connected between the motherboard and the bottom cover. Be careful not to pull the cable loose!
  3. HP Pavilion 11 x360 Motherboard Replacement, Detach Cable: passo 3, imagem 1 %32 HP Pavilion 11 x360 Motherboard Replacement, Detach Cable: passo 3, imagem 2 %32
    • Use the plastic opening tool to lift the white tab up at the connection.
    • Pull the cable outwards.
  4. HP Pavilion 11 x360 Motherboard Replacement, Battery: passo 4, imagem 1 %32
    • Remove the four 6mm screws from the battery with the PH0 screwdriver.
  5. HP Pavilion 11 x360 Motherboard Replacement: passo 5, imagem 1 %32 HP Pavilion 11 x360 Motherboard Replacement: passo 5, imagem 2 %32 HP Pavilion 11 x360 Motherboard Replacement: passo 5, imagem 3 %32
    • Use the spudger to pry up the blue/white speaker wires that are routed beside the battery.
  6. HP Pavilion 11 x360 Motherboard Replacement: passo 6, imagem 1 %32 HP Pavilion 11 x360 Motherboard Replacement: passo 6, imagem 2 %32
    • Remove the battery cable from the motherboard by gently pulling out on the black part of the cable closest to the white tab.
  7. HP Pavilion 11 x360 Motherboard Replacement: passo 7, imagem 1 %32 HP Pavilion 11 x360 Motherboard Replacement: passo 7, imagem 2 %32
    • Remove the battery.
  8. HP Pavilion 11 x360 Motherboard Replacement, Remove Screws: passo 8, imagem 1 %32
    • Remove the two 3mm screws with the PH0 screwdriver.
  9. HP Pavilion 11 x360 Motherboard Replacement, Disconnect Cable: passo 9, imagem 1 %32 HP Pavilion 11 x360 Motherboard Replacement, Disconnect Cable: passo 9, imagem 2 %32
    • Use your fingernails to slowly loosen the fan connection cable.
    • After the cable is slightly pulled from the connection, grab the cable and pull it outwards.
  10. HP Pavilion 11 x360 Motherboard Replacement, Remove Hard Drive: passo 10, imagem 1 %32 HP Pavilion 11 x360 Motherboard Replacement, Remove Hard Drive: passo 10, imagem 2 %32
    • Remove the three 3mm screws using the PH0 screwdriver.
    • Pull the hard drive slightly away from the connection to easily disconnect the hard drive cable from the motherboard.
    • Remove the hard drive.
  11. HP Pavilion 11 x360 Motherboard Replacement: passo 11, imagem 1 %32
    • Remove the four 3mm screws using the PH0 screwdriver.
  12. HP Pavilion 11 x360 Motherboard Replacement: passo 12, imagem 1 %32 HP Pavilion 11 x360 Motherboard Replacement: passo 12, imagem 2 %32 HP Pavilion 11 x360 Motherboard Replacement: passo 12, imagem 3 %32
    • Remove the two screws from the metal hinge on the power button side using the PH0 screwdriver.
    • One silver 4mm screw
    • One black 5mm screw
    • Lift up the hinge to remove the metal bracket underneath.
  13. HP Pavilion 11 x360 Motherboard Replacement: passo 13, imagem 1 %32 HP Pavilion 11 x360 Motherboard Replacement: passo 13, imagem 2 %32 HP Pavilion 11 x360 Motherboard Replacement: passo 13, imagem 3 %32
    • Remove one 3mm screw using the PH0 screwdriver from the metal hinge located on the power connector side of the computer.
    • Lift up the hinge with some force to remove the metal bracket underneath.
  14. HP Pavilion 11 x360 Motherboard Replacement, Disconnect the Wireless Card: passo 14, imagem 1 %32 HP Pavilion 11 x360 Motherboard Replacement, Disconnect the Wireless Card: passo 14, imagem 2 %32
    • Unscrew the two 3mm screws with the PH0 screwdriver.
    • Pull the wireless card out of its port to disconnect it from the motherboard.
  15. HP Pavilion 11 x360 Motherboard Replacement, Disconnect Keyboard Cable: passo 15, imagem 1 %32 HP Pavilion 11 x360 Motherboard Replacement, Disconnect Keyboard Cable: passo 15, imagem 2 %32 HP Pavilion 11 x360 Motherboard Replacement, Disconnect Keyboard Cable: passo 15, imagem 3 %32
    • Push the black tab away from the hinge of the laptop.
    • After the black tab has been flipped, pull out the blue cable to disconnect the keyboard cable.
  16. HP Pavilion 11 x360 Motherboard Replacement, Disconnect the Webcam Cable: passo 16, imagem 1 %32 HP Pavilion 11 x360 Motherboard Replacement, Disconnect the Webcam Cable: passo 16, imagem 2 %32
    • Pull horizontally toward the hinge of the laptop to disconnect the webcam cable.
  17. HP Pavilion 11 x360 Motherboard Replacement, Disconnect Display Cable: passo 17, imagem 1 %32 HP Pavilion 11 x360 Motherboard Replacement, Disconnect Display Cable: passo 17, imagem 2 %32 HP Pavilion 11 x360 Motherboard Replacement, Disconnect Display Cable: passo 17, imagem 3 %32
    • Pull up on the black tabs to disconnect the display cable.
  18. HP Pavilion 11 x360 Motherboard Replacement, Disconnect Power Button Board: passo 18, imagem 1 %32 HP Pavilion 11 x360 Motherboard Replacement, Disconnect Power Button Board: passo 18, imagem 2 %32
    • Pull the cable horizontally away from the motherboard to disconnect the power button board cable.
  19. HP Pavilion 11 x360 Motherboard Replacement, Disconnect the Power Connector Cable: passo 19, imagem 1 %32 HP Pavilion 11 x360 Motherboard Replacement, Disconnect the Power Connector Cable: passo 19, imagem 2 %32
    • Pull the cable horizontally away from the motherboard to disconnect the power connector cable.
  20. HP Pavilion 11 x360 Motherboard Replacement, Disconnect Speaker Cable: passo 20, imagem 1 %32 HP Pavilion 11 x360 Motherboard Replacement, Disconnect Speaker Cable: passo 20, imagem 2 %32
    • Pull the cable horizontally away from the motherboard to disconnect the speaker cable.
  21. HP Pavilion 11 x360 Motherboard Replacement, Remove Touch Pad Cable: passo 21, imagem 1 %32 HP Pavilion 11 x360 Motherboard Replacement, Remove Touch Pad Cable: passo 21, imagem 2 %32 HP Pavilion 11 x360 Motherboard Replacement, Remove Touch Pad Cable: passo 21, imagem 3 %32
    • Push the white tab up toward the hinge of the laptop.
    • Disconnect touch pad cable by pulling up and away from the motherboard.
  22. HP Pavilion 11 x360 Motherboard Replacement: passo 22, imagem 1 %32 HP Pavilion 11 x360 Motherboard Replacement: passo 22, imagem 2 %32
    • Lift up to remove the motherboard.
  23. HP Pavilion 11 x360 Motherboard Replacement: passo 23, imagem 1 %32 HP Pavilion 11 x360 Motherboard Replacement: passo 23, imagem 2 %32 HP Pavilion 11 x360 Motherboard Replacement: passo 23, imagem 3 %32
    • Push outwards on the two black tabs to pop the RAM up.
  24. HP Pavilion 11 x360 Motherboard Replacement: passo 24, imagem 1 %32
    • Remove the RAM.
  25. HP Pavilion 11 x360 Motherboard Replacement: passo 25, imagem 1 %32 HP Pavilion 11 x360 Motherboard Replacement: passo 25, imagem 2 %32
    • Lift up the heat sink to remove it from the motherboard.
Conclusão
10 outras pessoas executaram este guia.
Emily
Membro desde: 01/22/15
487 Reputação
Autoria de 1 guia
Equipe
Cal Poly, Team 19-9, Maness Winter 2015 Membro de Cal Poly, Team 19-9, Maness Winter 2015
CPSU-MANESS-W15S19G9
Membros da 4
Autoria de 12 guias
Um comentário
La tarjeta madre soportara un intel core i5?
Rodolfo Giron - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 7
Últimos 30 dias: 43
Duração total: 10,567
