Ir para o conteúdo principal
HP Pavilion 11 x360 Fan Replacement
O que você precisa
  1. HP Pavilion 11 x360 Fan Replacement, Remove Screws: passo 1, imagem 1 %32 HP Pavilion 11 x360 Fan Replacement, Remove Screws: passo 1, imagem 2 %32
    • Use the spudger to pry off the two rubber feet near the hinge of the laptop. This will reveal two hidden 9mm screws.
    • You must remove eleven screws.
    • Four 9mm screws with the PH0 screwdriver.
    • Seven 6mm screws with the PH0 screwdriver.
  2. HP Pavilion 11 x360 Fan Replacement, Remove Backing: passo 2, imagem 1 %32 HP Pavilion 11 x360 Fan Replacement, Remove Backing: passo 2, imagem 2 %32 HP Pavilion 11 x360 Fan Replacement, Remove Backing: passo 2, imagem 3 %32
    • Use the spudger to pry the corners of the laptop near the display hinges.
    • Pry around the seam of the laptop with the plastic opening tool until the backing begins to pull apart.
    • When you lift the bottom cover, there is a cable connected between the motherboard and the bottom cover. Be careful not to pull the cable loose!
  3. HP Pavilion 11 x360 Fan Replacement, Detach Cable: passo 3, imagem 1 %32 HP Pavilion 11 x360 Fan Replacement, Detach Cable: passo 3, imagem 2 %32
    • Use the plastic opening tool to lift the white tab up at the connection.
    • Pull the cable outwards.
  4. HP Pavilion 11 x360 Fan Replacement, Remove Screws: passo 4, imagem 1 %32
    • Remove the two 3mm screws with the PH0 screwdriver.
  5. HP Pavilion 11 x360 Fan Replacement, Disconnect Cable: passo 5, imagem 1 %32 HP Pavilion 11 x360 Fan Replacement, Disconnect Cable: passo 5, imagem 2 %32
    • Use your fingernails to slowly loosen the fan connection cable.
    • After the cable is slightly pulled from the connection, grab the cable and pull it outwards.
Conclusão
6 outras pessoas executaram este guia.
Natalie
Membro desde: 01/22/15
937 Reputação
Autoria de 4 guias
Equipe
Cal Poly, Team 19-9, Maness Winter 2015 Membro de Cal Poly, Team 19-9, Maness Winter 2015
CPSU-MANESS-W15S19G9
Membros da 4
Autoria de 12 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 25
Duração total: 2,620
