O que você precisa
Flip the unit so that the screen faces down.
At each side, remove the Philips screw.
Separate the back cover from the bezel with a spudger, then pull like you're gonna go mad!
Remove the two Philips screws securing the metal cover, and remove the cover.
Remove the three Philips screws of a different size than before that are securing the fan.
Trace the fan cable and remove the connector from the motherboard.
Quase terminado!
Conclusão
