Ir para o conteúdo principal
HP Omen 15-ax243dx Speaker Replacement
O que você precisa
  1. HP Omen 15-ax243dx Speaker Replacement, Battery: passo 1, imagem 1 %32 HP Omen 15-ax243dx Speaker Replacement, Battery: passo 1, imagem 2 %32
    • The rear panel is secured by 10 screws. Using a #00 Phillips Screwdriver, remove the ten 1.2 mm screws.
    • The screwdriver should be inserted at the same angle as the screws.
    • Be sure to keep track of the screws and where they came from. Some only fit in to one spot.
  2. HP Omen 15-ax243dx Speaker Replacement: passo 2, imagem 1 %32 HP Omen 15-ax243dx Speaker Replacement: passo 2, imagem 2 %32
    • Insert a plastic opening tool between the rear panel and the top case. Pry the opening tool upwards to separate the top case from the bottom case.
    • Slide the opening tool along the case perimeter to loosen the bottom case.
    • Gently pull the bottom case away from the laptop.
  3. HP Omen 15-ax243dx Speaker Replacement: passo 3, imagem 1 %32 HP Omen 15-ax243dx Speaker Replacement: passo 3, imagem 2 %32
    • Remove the four 1.2 mm Phillips #00 screws around the battery.
  4. HP Omen 15-ax243dx Speaker Replacement: passo 4, imagem 1 %32 HP Omen 15-ax243dx Speaker Replacement: passo 4, imagem 2 %32
    • Pull the battery cable out from its motherboard socket.
    • Pull parallel to the motherboard, not straight up.
    • Remove the battery.
    • Disconnect the power cord from the battery and transfer it to your replacement battery.
  5. HP Omen 15-ax243dx Speaker Replacement, Hard-Drive: passo 5, imagem 1 %32
    • After the battery is removed, the hard drive will be easier to access in the top right hand corner.
  6. HP Omen 15-ax243dx Speaker Replacement: passo 6, imagem 1 %32 HP Omen 15-ax243dx Speaker Replacement: passo 6, imagem 2 %32 HP Omen 15-ax243dx Speaker Replacement: passo 6, imagem 3 %32
    • With a opening tool, flip open the switch that locks in the hard drive ribbon cable into the device.
    • When lifting the cable out, lift straight up and out to prevent damage to the connector or cable.
  7. HP Omen 15-ax243dx Speaker Replacement: passo 7, imagem 1 %32
    • Lift the hard drive up to remove from the device
  8. HP Omen 15-ax243dx Speaker Replacement: passo 8, imagem 1 %32 HP Omen 15-ax243dx Speaker Replacement: passo 8, imagem 2 %32 HP Omen 15-ax243dx Speaker Replacement: passo 8, imagem 3 %32
    • Remove the rubber guards on the side of the hard drive.
    • Gently pull the plastic connector out from the hard drive.
    • The hard drive can now be disposed of if needed.
    • Save the guards and connectors from this hard drive, they will be used on the replacement part.
  9. HP Omen 15-ax243dx Speaker Replacement, Ventilation Fans: passo 9, imagem 1 %32
    • The two ventilation fans are secured with the system by 5 screws. Unscrew these five 1.2 mm screws using the Phillips #0 screwdriver.
    • When removing the screws, use a magnetic screwdriver to prevent the screws from falling behind the motherboard
  10. HP Omen 15-ax243dx Speaker Replacement: passo 10, imagem 1 %32 HP Omen 15-ax243dx Speaker Replacement: passo 10, imagem 2 %32
    • After removing all 5 screws, the fans are still connected with the system through 2 cables.
    • Carefully pull the fan cables out of the connectors on the motherboard.
    • Be cautious when pulling by the wires, this can permanently damage the fans beyond repair.
  11. HP Omen 15-ax243dx Speaker Replacement: passo 11, imagem 1 %32
    • The fans can now be removed from the device.
  12. HP Omen 15-ax243dx Speaker Replacement, Speaker: passo 12, imagem 1 %32 HP Omen 15-ax243dx Speaker Replacement, Speaker: passo 12, imagem 2 %32 HP Omen 15-ax243dx Speaker Replacement, Speaker: passo 12, imagem 3 %32
    • Disconnect all the ribbon cables highlighted.
    • Be sure to use the plastic opening tool when flipping the switches up on the cable connectors.
  13. HP Omen 15-ax243dx Speaker Replacement: passo 13, imagem 1 %32 HP Omen 15-ax243dx Speaker Replacement: passo 13, imagem 2 %32 HP Omen 15-ax243dx Speaker Replacement: passo 13, imagem 3 %32
    • Unplug the wire the connects to the speakers.
  14. HP Omen 15-ax243dx Speaker Replacement: passo 14, imagem 1 %32 HP Omen 15-ax243dx Speaker Replacement: passo 14, imagem 2 %32
    • Unscrew the six 1.2 mm screws connecting the screen to the body using the #0 Phillips screwdriver.
    • Be cautious of where the screws come out from, some will only fit in the same location.
  15. HP Omen 15-ax243dx Speaker Replacement: passo 15, imagem 1 %32 HP Omen 15-ax243dx Speaker Replacement: passo 15, imagem 2 %32 HP Omen 15-ax243dx Speaker Replacement: passo 15, imagem 3 %32
    • Remove the tape holding the wires down
    • Disconnect the wires from the wifi chip
    • When removing the wires from the wifi chip, be careful to not damage the connectors.
  16. HP Omen 15-ax243dx Speaker Replacement: passo 16, imagem 1 %32 HP Omen 15-ax243dx Speaker Replacement: passo 16, imagem 2 %32
    • Unscrew the two 1.2 mm screws holding the motherboard to the front panel using the same screwdriver.
  17. HP Omen 15-ax243dx Speaker Replacement: passo 17, imagem 1 %32
    • Lift the back of the motherboard up then slide the audio cable out between the heatsink and motherboard
  18. HP Omen 15-ax243dx Speaker Replacement: passo 18, imagem 1 %32 HP Omen 15-ax243dx Speaker Replacement: passo 18, imagem 2 %32
    • Lift the back of the motherboard up again and remove the charging adapter.
    • This wire is located in a tight spot. Pull it straight out and do not bend it, this will cause irreparable damage to the device.
  19. HP Omen 15-ax243dx Speaker Replacement: passo 19, imagem 1 %32 HP Omen 15-ax243dx Speaker Replacement: passo 19, imagem 2 %32 HP Omen 15-ax243dx Speaker Replacement: passo 19, imagem 3 %32
    • Slowly lift up the back of the motherboard.
    • The board is friction fit at the rotation point. Be careful to lift the board around this point.
    • The board will now lift out of the device.
  20. HP Omen 15-ax243dx Speaker Replacement: passo 20, imagem 1 %32 HP Omen 15-ax243dx Speaker Replacement: passo 20, imagem 2 %32 HP Omen 15-ax243dx Speaker Replacement: passo 20, imagem 3 %32
    • Lift up the keyboard panel of the device and set it back down.
    • The speaker in the top left hand corner can be taken out of its place.
  21. HP Omen 15-ax243dx Speaker Replacement: passo 21, imagem 1 %32 HP Omen 15-ax243dx Speaker Replacement: passo 21, imagem 2 %32
    • Remove the tape between the two speakers
    • The left speaker can now be removed.
    • The speakers can be disposed of if needed now.
Conclusão
Uma outra pessoa concluiu este guia.
Dean Lee
Membro desde: 10/19/17
360 Reputação
Autoria de 2 guias
Equipe
UMass Dartmouth, Team S6-G7, Rockett Fall 2017 Membro de UMass Dartmouth, Team S6-G7, Rockett Fall 2017
UMASSD-ROCKETT-F17S6G7
Membros da 3
Autoria de 7 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 4
Últimos 30 dias: 16
Duração total: 2,650
