Ir para o conteúdo principal
HP Omen 15-5002xx Keyboard Replacement
O que você precisa
  1. HP Omen 15-5002xx Keyboard Replacement, Back Cover: passo 1, imagem 1 %32 HP Omen 15-5002xx Keyboard Replacement, Back Cover: passo 1, imagem 2 %32
    • Flip the laptop upside down so the backside is facing up.
    • Use a spudger or your fingers to remove the thin rubber strips that are attached from the edges of the laptop.
    • Remember where each thin rubber came from and set them off to the side.
    • Unscrew all 14 screw with the J00 JIS Screwdriver.
  2. HP Omen 15-5002xx Keyboard Replacement, Battery: passo 2, imagem 1 %32
    • Open the case slowly from opposite sides of the laptop.
    • Use the J00 JIS screwdriver to remove eight screws securing the battery.
  3. HP Omen 15-5002xx Keyboard Replacement: passo 3, imagem 1 %32 HP Omen 15-5002xx Keyboard Replacement: passo 3, imagem 2 %32
    • Carefully remove the battery connector that is attached to the motherboard by slowly sliding it towards the battery with two fingers.
    • Remove the battery by lifting it up and out.
  4. HP Omen 15-5002xx Keyboard Replacement, Fan: passo 4, imagem 1 %32
    Ferramenta utilizada nesse passo:
    Flathead 1.5 mm Screwdriver
    $5.49
    Comprar
    • Remove the twelve big screws with the J00 JIS screwdriver.
    • Remove all eight small screws with the 1.5 flathead screwdriver.
  5. HP Omen 15-5002xx Keyboard Replacement: passo 5, imagem 1 %32 HP Omen 15-5002xx Keyboard Replacement: passo 5, imagem 2 %32
    • Carefully detach the fan connector that is attached to the motherboard by slowly sliding the connector out with two fingers.
    • Remove the battery carefully.
  6. HP Omen 15-5002xx Keyboard Replacement, Wi-Fi Card: passo 6, imagem 1 %32
    • Use the Phillips #00 to remove one screw securing the Wi-Fi Card.
  7. HP Omen 15-5002xx Keyboard Replacement: passo 7, imagem 1 %32
    • Carefully remove the Wi-Fi Card by slowly sliding the card sideways away from the motherboard.
  8. HP Omen 15-5002xx Keyboard Replacement, Motherboard: passo 8, imagem 1 %32
    $5.49
    Comprar
    • Use the 1.5 flathead screwdriver and remove the twelve screws from the motherboard.
  9. HP Omen 15-5002xx Keyboard Replacement: passo 9, imagem 1 %32 HP Omen 15-5002xx Keyboard Replacement: passo 9, imagem 2 %32 HP Omen 15-5002xx Keyboard Replacement: passo 9, imagem 3 %32
    • Disconnect the four cables attached to the motherboard.
  10. HP Omen 15-5002xx Keyboard Replacement: passo 10, imagem 1 %32 HP Omen 15-5002xx Keyboard Replacement: passo 10, imagem 2 %32
    • Disconnect the remaining four connectors from the motherboard.
    • Remove the motherboard.
  11. HP Omen 15-5002xx Keyboard Replacement, Keyboard: passo 11, imagem 1 %32
    $5.49
    Comprar
    • Remove all 51 screws using the 1.5 mm flathead screwdriver from the underside of the keyboard.
    • All necessary screws are numbered from 1-51 on the side of each screw hole.
  12. HP Omen 15-5002xx Keyboard Replacement: passo 12, imagem 1 %32 HP Omen 15-5002xx Keyboard Replacement: passo 12, imagem 2 %32
    • Slowly pull the electricity tape off of the computer.
    • You are able to replace the electricity tape or keep the tape attached with the wire.
  13. HP Omen 15-5002xx Keyboard Replacement: passo 13, imagem 1 %32 HP Omen 15-5002xx Keyboard Replacement: passo 13, imagem 2 %32
    • With two hands, lift the keyboards from the sides.
Conclusão
Hassan Isse
Membro desde: 09/01/21
97 Reputação
Autoria de 1 guia
Equipe
Gateway, Team 1-1, Saknee Fall 2021 Membro de Gateway, Team 1-1, Saknee Fall 2021
GCC-SAKNEE-F21S1G1
Membros da 5
Autoria de 6 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 6
Últimos 30 dias: 42
Duração total: 1,185
