Ir para o conteúdo principal
HP Omen 15-5002xx Fan Replacement
O que você precisa
  1. HP Omen 15-5002xx Fan Replacement, Back Cover: passo 1, imagem 1 %32 HP Omen 15-5002xx Fan Replacement, Back Cover: passo 1, imagem 2 %32
    • Flip the laptop upside down so the backside is facing up.
    • Use a spudger or your fingers to remove the thin rubber strips that are attached from the edges of the laptop.
    • Remember where each thin rubber came from and set them off to the side.
    • Unscrew all 14 screw with the J00 JIS Screwdriver.
  2. HP Omen 15-5002xx Fan Replacement, Battery: passo 2, imagem 1 %32
    • Open the case slowly from opposite sides of the laptop.
    • Use the J00 JIS screwdriver to remove eight screws securing the battery.
  3. HP Omen 15-5002xx Fan Replacement: passo 3, imagem 1 %32 HP Omen 15-5002xx Fan Replacement: passo 3, imagem 2 %32
    • Carefully remove the battery connector that is attached to the motherboard by slowly sliding it towards the battery with two fingers.
    • Remove the battery by lifting it up and out.
  4. HP Omen 15-5002xx Fan Replacement, Fan: passo 4, imagem 1 %32
    Ferramenta utilizada nesse passo:
    Flathead 1.5 mm Screwdriver
    $5.49
    Comprar
    • Remove the twelve big screws with the J00 JIS screwdriver.
    • Remove all eight small screws with the 1.5 flathead screwdriver.
  5. HP Omen 15-5002xx Fan Replacement: passo 5, imagem 1 %32 HP Omen 15-5002xx Fan Replacement: passo 5, imagem 2 %32
    • Carefully detach the fan connector that is attached to the motherboard by slowly sliding the connector out with two fingers.
    • Remove the battery carefully.
Conclusão
Eduardo Arellano
Membro desde: 09/01/21
621 Reputação
Autoria de 5 guias
Equipe
Gateway, Team 1-1, Saknee Fall 2021 Membro de Gateway, Team 1-1, Saknee Fall 2021
GCC-SAKNEE-F21S1G1
Membros da 5
Autoria de 6 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 8
Últimos 30 dias: 42
Duração total: 1,647
