Ir para o conteúdo principal
HP Officejet Pro 8625 Power Supply Replacement
O que você precisa
  1. HP Officejet Pro 8625 Power Supply Replacement, Left Side Panel: passo 1, imagem 1 %32 HP Officejet Pro 8625 Power Supply Replacement, Left Side Panel: passo 1, imagem 2 %32 HP Officejet Pro 8625 Power Supply Replacement, Left Side Panel: passo 1, imagem 3 %32
    • Remove the two 11.6 mm T9 screws from the right side of the back of the printer.
  2. HP Officejet Pro 8625 Power Supply Replacement: passo 2, imagem 1 %32 HP Officejet Pro 8625 Power Supply Replacement: passo 2, imagem 2 %32 HP Officejet Pro 8625 Power Supply Replacement: passo 2, imagem 3 %32
    • Pull down the front panel to expose the screws on the front.
    • Remove the one 11.6 mm T9 screw on the left side of the front face.
  3. HP Officejet Pro 8625 Power Supply Replacement: passo 3, imagem 1 %32 HP Officejet Pro 8625 Power Supply Replacement: passo 3, imagem 2 %32
    • Remove the side panel by pushing down and towards the back.
    • This step may be easier if the printer is laid on its side with the left side panel facing up.
  4. HP Officejet Pro 8625 Power Supply Replacement, Power Supply: passo 4, imagem 1 %32 HP Officejet Pro 8625 Power Supply Replacement, Power Supply: passo 4, imagem 2 %32 HP Officejet Pro 8625 Power Supply Replacement, Power Supply: passo 4, imagem 3 %32
    • Remove the the black cable from the bottom of the motherboard by carefully pulling down on the connection.
  5. HP Officejet Pro 8625 Power Supply Replacement: passo 5, imagem 1 %32 HP Officejet Pro 8625 Power Supply Replacement: passo 5, imagem 2 %32
    • Remove the two 9.3 mm T9 screws that attach the power supply to the bottom of the printer.
  6. HP Officejet Pro 8625 Power Supply Replacement: passo 6, imagem 1 %32 HP Officejet Pro 8625 Power Supply Replacement: passo 6, imagem 2 %32
    • Slide the power supply out of the printer by pulling towards you.
    • Be careful of the wires coming from the motherboard.
Conclusão
Cole Andrews
Membro desde: 10/08/18
273 Reputação
Autoria de 2 guias
Equipe
Cal Poly, Team S13-G3, White Fall 2018 Membro de Cal Poly, Team S13-G3, White Fall 2018
CPSU-WHITE-F18S13G3
Membros da 3
Autoria de 14 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 13
Duração total: 452
