Introdução
If your HP Officejet Pro 8625 is having trouble turning on, you can replace the motherboard using this guide. You will need a TR9 Torx screwdriver for each screw in this guide. The steps are not very difficult but be careful when removing the connectors.
O que você precisa
Remove the two 11.6 mm T9 screws from the right side of the back of the printer.
Remove the three 5.3 mm T9 screws from the motherboard.
Remove the one 6.7 mm T9 screw from the motherboard.
