Ir para o conteúdo principal
HP Officejet Pro 8625 CMOS Battery Replacement
O que você precisa
  1. HP Officejet Pro 8625 CMOS Battery Replacement, Left Side Panel: passo 1, imagem 1 %32 HP Officejet Pro 8625 CMOS Battery Replacement, Left Side Panel: passo 1, imagem 2 %32 HP Officejet Pro 8625 CMOS Battery Replacement, Left Side Panel: passo 1, imagem 3 %32
    • Remove the two 11.6 mm T9 screws from the right side of the back of the printer.
  2. HP Officejet Pro 8625 CMOS Battery Replacement: passo 2, imagem 1 %32 HP Officejet Pro 8625 CMOS Battery Replacement: passo 2, imagem 2 %32 HP Officejet Pro 8625 CMOS Battery Replacement: passo 2, imagem 3 %32
    • Pull down the front panel to expose the screws on the front.
    • Remove the one 11.6 mm T9 screw on the left side of the front face.
  3. HP Officejet Pro 8625 CMOS Battery Replacement: passo 3, imagem 1 %32 HP Officejet Pro 8625 CMOS Battery Replacement: passo 3, imagem 2 %32
    • Remove the side panel by pushing down and towards the back.
    • This step may be easier if the printer is laid on its side with the left side panel facing up.
  4. HP Officejet Pro 8625 CMOS Battery Replacement, Motherboard: passo 4, imagem 1 %32 HP Officejet Pro 8625 CMOS Battery Replacement, Motherboard: passo 4, imagem 2 %32 HP Officejet Pro 8625 CMOS Battery Replacement, Motherboard: passo 4, imagem 3 %32
    • Remove the three 5.3 mm T9 screws from the motherboard.
    • Remove the one 6.7 mm T9 screw from the motherboard.
  5. HP Officejet Pro 8625 CMOS Battery Replacement: passo 5, imagem 1 %32 HP Officejet Pro 8625 CMOS Battery Replacement: passo 5, imagem 2 %32
    • Remove the connectors from the front and sides of the motherboard by pulling straight away from the connection.
  6. HP Officejet Pro 8625 CMOS Battery Replacement: passo 6, imagem 1 %32 HP Officejet Pro 8625 CMOS Battery Replacement: passo 6, imagem 2 %32 HP Officejet Pro 8625 CMOS Battery Replacement: passo 6, imagem 3 %32
    • Lift the bottom of the motherboard and remove the connectors from the back.
    • Remove the motherboard.
    • There are two white connectors underneath the motherboard, remove them separately.
  7. HP Officejet Pro 8625 CMOS Battery Replacement, CMOS Battery: passo 7, imagem 1 %32 HP Officejet Pro 8625 CMOS Battery Replacement, CMOS Battery: passo 7, imagem 2 %32 HP Officejet Pro 8625 CMOS Battery Replacement, CMOS Battery: passo 7, imagem 3 %32
    • Locate the CMOS battery on the motherboard.
    • Remove the CMOS battery by pinching the top and pulling away from the motherboard.
Conclusão
Cam Engle
Membro desde: 10/08/18
555 Reputação
Autoria de 3 guias
Equipe
Cal Poly, Team S13-G3, White Fall 2018 Membro de Cal Poly, Team S13-G3, White Fall 2018
CPSU-WHITE-F18S13G3
Membros da 3
Autoria de 14 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 8
Últimos 30 dias: 13
Duração total: 566
