Ir para o conteúdo principal
HP Officejet Pro 8620 Power Button Replacement
O que você precisa
  1. HP Officejet Pro 8620 Power Button Replacement, Power Button: passo 1, imagem 1 %32 HP Officejet Pro 8620 Power Button Replacement, Power Button: passo 1, imagem 2 %32 HP Officejet Pro 8620 Power Button Replacement, Power Button: passo 1, imagem 3 %32
    • Locate the power button on the bottom left side of the device.
    • Wedge the opening tool into the small gap between the power button panel and printer.
    • Apply pressure on the opening tool and open the power button panel.
    • Gently remove the power button panel assembly from the printer to access the power button.
  2. HP Officejet Pro 8620 Power Button Replacement: passo 2, imagem 1 %32 HP Officejet Pro 8620 Power Button Replacement: passo 2, imagem 2 %32
    • Press on the power button from the front of the panel to release it.
  3. HP Officejet Pro 8620 Power Button Replacement: passo 3, imagem 1 %32 HP Officejet Pro 8620 Power Button Replacement: passo 3, imagem 2 %32
    • Turn the panel around so you are viewing the back of it.
    • Disconnect the power button from the panel by gently pulling the button out (toward your body).
    • Be careful not to crack the connector of the button panel when pulling the power button
Conclusão
Scott
Membro desde: 01/24/18
593 Reputação
Autoria de 3 guias
Equipe
Cal Poly, Team S19-G2, Livingston Spring 2018 Membro de Cal Poly, Team S19-G2, Livingston Spring 2018
CPSU-LIVINGSTON-S18S19G2
1 Membro
Autoria de 6 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 6
Últimos 30 dias: 28
Duração total: 2,533
