Ir para o conteúdo principal
HP Officejet Pro 8620 Power Adapter Replacement
O que você precisa
  1. HP Officejet Pro 8620 Power Adapter Replacement, Left Panel: passo 1, imagem 1 %32 HP Officejet Pro 8620 Power Adapter Replacement, Left Panel: passo 1, imagem 2 %32 HP Officejet Pro 8620 Power Adapter Replacement, Left Panel: passo 1, imagem 3 %32
    • Turn off the printer and remove the power cable.
    • Remove two 13mm T9 screws using a T9-Torx screwdriver. Turn counterclockwise until the screws are released.
  2. HP Officejet Pro 8620 Power Adapter Replacement: passo 2, imagem 1 %32 HP Officejet Pro 8620 Power Adapter Replacement: passo 2, imagem 2 %32
    • Open the front door by placing your finger on the indented groove on the left side of the printer and pulling down
    • This will give you access to the two T9-TORX 13mm screws that need to be removed to release the panel.
  3. HP Officejet Pro 8620 Power Adapter Replacement: passo 3, imagem 1 %32 HP Officejet Pro 8620 Power Adapter Replacement: passo 3, imagem 2 %32
    • Remove the two 13mm screws with a T9-TORX screwdriver by turning counter-clockwise (left).
  4. HP Officejet Pro 8620 Power Adapter Replacement: passo 4, imagem 1 %32 HP Officejet Pro 8620 Power Adapter Replacement: passo 4, imagem 2 %32 HP Officejet Pro 8620 Power Adapter Replacement: passo 4, imagem 3 %32
    • Gently remove the left side panel by placing your palm flat against the surface and pulling down.
  5. HP Officejet Pro 8620 Power Adapter Replacement, Power Adapter: passo 5, imagem 1 %32 HP Officejet Pro 8620 Power Adapter Replacement, Power Adapter: passo 5, imagem 2 %32 HP Officejet Pro 8620 Power Adapter Replacement, Power Adapter: passo 5, imagem 3 %32
    • Remove two screws 13mm screws with a T9-Torx screwdriver by rotating them counterclockwise.
  6. HP Officejet Pro 8620 Power Adapter Replacement: passo 6, imagem 1 %32 HP Officejet Pro 8620 Power Adapter Replacement: passo 6, imagem 2 %32 HP Officejet Pro 8620 Power Adapter Replacement: passo 6, imagem 3 %32
    • Unplug the black cable .
    • Move all the cables and wires to the top of the motherboard to allow the power adapter underneath to be removed freely.
  7. HP Officejet Pro 8620 Power Adapter Replacement: passo 7, imagem 1 %32
    • Gently bend the black ribbon cable.
    • Remove one 8mm T8 screw underneath the ribbon cable by rotating it counterclockwise with a T8 -Torx screwdriver.
    • Take out the black plastic cover and the colored wires connected to it.
    • Now you have cleared a passage for the power adapter to be taken out.
  8. HP Officejet Pro 8620 Power Adapter Replacement: passo 8, imagem 1 %32
    • Gently pulling out the power adapter.
    • Be careful with all the wires when pulling out the adapter.
Conclusão
Scott
Membro desde: 01/24/18
593 Reputação
Autoria de 3 guias
Equipe
Cal Poly, Team S19-G2, Livingston Spring 2018 Membro de Cal Poly, Team S19-G2, Livingston Spring 2018
CPSU-LIVINGSTON-S18S19G2
1 Membro
Autoria de 6 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 5
Últimos 30 dias: 19
Duração total: 2,178
