Ir para o conteúdo principal
HP Officejet Pro 8620 Display Replacement
O que você precisa
  1. HP Officejet Pro 8620 Display Replacement, Display: passo 1, imagem 1 %32 HP Officejet Pro 8620 Display Replacement, Display: passo 1, imagem 2 %32
    • Place the printer on its back and rotate the display clockwise to gain access to the underside of the display.
  2. HP Officejet Pro 8620 Display Replacement: passo 2, imagem 1 %32 HP Officejet Pro 8620 Display Replacement: passo 2, imagem 2 %32 HP Officejet Pro 8620 Display Replacement: passo 2, imagem 3 %32
    • Locate the control arm on the underside of the display. You will need to detach this to access the screws.
    • Place a finger behind the control arm.
    • Separate the display unit from the control arm by pulling down with your finger and using your other hand to push the display unit up.
    • Removing the control arm takes a moderate amount of force.
  3. HP Officejet Pro 8620 Display Replacement: passo 3, imagem 1 %32 HP Officejet Pro 8620 Display Replacement: passo 3, imagem 2 %32 HP Officejet Pro 8620 Display Replacement: passo 3, imagem 3 %32
    • Remove the four 11mm T9-Torx screws on the underside of the display unit by rotating the screwdriver counter clockwise.
    • Open the display unit to expose the circuit board by separating the back and front panels.
    • Remove the ribbon cable by gently releasing the plastic locking mechanism and pulling the cable away from the circuit board.
  4. HP Officejet Pro 8620 Display Replacement: passo 4, imagem 1 %32 HP Officejet Pro 8620 Display Replacement: passo 4, imagem 2 %32
    • Remove the four 7mm T9-Torx screws from the circuit board that are holding the screen in place using a T9-Torx screwdriver and turning counter clockwise.
    • Lift the circuit board/screen panel from the black frame.
Conclusão
4 outras pessoas executaram este guia.
Dallas Rocha
Membro desde: 01/24/18
243 Reputação
Autoria de 1 guia
Equipe
Cal Poly, Team S19-G2, Livingston Winter 2018 Membro de Cal Poly, Team S19-G2, Livingston Winter 2018
CPSU-LIVINGSTON-W18S19G2
Membros da 3
Autoria de 8 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 6
Últimos 30 dias: 22
Duração total: 4,957
