Ir para o conteúdo principal
HP Officejet Pro 8600 Plus Front Panel Replacement
O que você precisa
  1. HP Officejet Pro 8600 Plus Front Panel Replacement, Front Panel: passo 1, imagem 1 %32 HP Officejet Pro 8600 Plus Front Panel Replacement, Front Panel: passo 1, imagem 2 %32
    • Open the front panel door by pulling forward on the slot located on the front-left side of the printer.
  2. HP Officejet Pro 8600 Plus Front Panel Replacement: passo 2, imagem 1 %32 HP Officejet Pro 8600 Plus Front Panel Replacement: passo 2, imagem 2 %32
    • Insert the plastic opening tool into the right socket connecting the front panel door to the hinge guide.
    • Pry the socket open, lifting the door hinge guide out of place.
  3. HP Officejet Pro 8600 Plus Front Panel Replacement: passo 3, imagem 1 %32 HP Officejet Pro 8600 Plus Front Panel Replacement: passo 3, imagem 2 %32
    • Pull the door-hinge guide to the right to detach its left socket.
    • Lift the door-hinge guide upward and away from the front panel door.
  4. HP Officejet Pro 8600 Plus Front Panel Replacement: passo 4, imagem 1 %32 HP Officejet Pro 8600 Plus Front Panel Replacement: passo 4, imagem 2 %32
    • Grab the front panel door close to its hinge on the right side.
    • Pull the front panel door away from the printer toward you.
    • Extra force may be required to pull the door from its hinge.
  5. HP Officejet Pro 8600 Plus Front Panel Replacement: passo 5, imagem 1 %32 HP Officejet Pro 8600 Plus Front Panel Replacement: passo 5, imagem 2 %32 HP Officejet Pro 8600 Plus Front Panel Replacement: passo 5, imagem 3 %32
    • Grab the front panel door close to its two hinges on the left side.
    • Extra force may be required to pull the door from its hinges.
Conclusão
Maegan Betz
Membro desde: 04/18/18
301 Reputação
Autoria de 1 guia
Equipe
Cal Poly, Team S16-G4, Livingston Spring 2018 Membro de Cal Poly, Team S16-G4, Livingston Spring 2018
CPSU-LIVINGSTON-S18S16G4
Membros da 4
Autoria de 10 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 26
Duração total: 3,733
