Ir para o conteúdo principal
HP Officejet Pro 8600 Plus Battery Replacement
O que você precisa
  1. HP Officejet Pro 8600 Plus Battery Replacement, Motherboard: passo 1, imagem 1 %32 HP Officejet Pro 8600 Plus Battery Replacement, Motherboard: passo 1, imagem 2 %32
    • Turn the printer so the back is facing you.
    • Put the printer in a vertical position by lifting its right side.
  2. HP Officejet Pro 8600 Plus Battery Replacement: passo 2, imagem 1 %32
    • Remove the two 12mm T10 Torx screws on the top edge of the printer.
  3. HP Officejet Pro 8600 Plus Battery Replacement: passo 3, imagem 1 %32
    • Rotate the printer clockwise so the bottom of the printer is facing you.
  4. HP Officejet Pro 8600 Plus Battery Replacement: passo 4, imagem 1 %32 HP Officejet Pro 8600 Plus Battery Replacement: passo 4, imagem 2 %32
    • Insert the plastic opening tool underneath the slot on the right that aligns with the edge of the back panel.
    • Insert a second plastic opening tool in the notch lining up with the crease in the back panel.
    • This step requires applying a significant amount of force on the left notch. Don't be alarmed if you hear popping noises.
  5. HP Officejet Pro 8600 Plus Battery Replacement: passo 5, imagem 1 %32
    • Remove the side panel from the printer by lifting upwards toward you.
    • For reassembly, slide the side panel from left to right into place.
  6. HP Officejet Pro 8600 Plus Battery Replacement: passo 6, imagem 1 %32
    • Remove the four 6.5 mm T10 Torx screws from the motherboard.
  7. HP Officejet Pro 8600 Plus Battery Replacement: passo 7, imagem 1 %32
    • Remove the black brace from the right side of the motherboard, located near the black ribbon cable.
  8. HP Officejet Pro 8600 Plus Battery Replacement: passo 8, imagem 1 %32 HP Officejet Pro 8600 Plus Battery Replacement: passo 8, imagem 2 %32 HP Officejet Pro 8600 Plus Battery Replacement: passo 8, imagem 3 %32
    • Remove the cables connected to the top of the motherboard by gently pulling them out of their ports.
    • Remove the cables connected to the edge of the motherboard by gently pulling them out of their ports.
    • Remove the cables connected to the underside of the motherboard by gently pulling them out of their ports.
  9. HP Officejet Pro 8600 Plus Battery Replacement, Battery: passo 9, imagem 1 %32 HP Officejet Pro 8600 Plus Battery Replacement, Battery: passo 9, imagem 2 %32
    • Turn the motherboard over so the back is facing upward.
    • Use the plastic opening tool to pry the battery out of place.
  10. HP Officejet Pro 8600 Plus Battery Replacement: passo 10, imagem 1 %32
    • Remove the battery by grabbing its edges, lifting upward, and sliding sideways.
Conclusão
9 outras pessoas executaram este guia.
Mackinnon Buck
Membro desde: 04/18/18
1.182 Reputação
Autoria de 3 guias
Equipe
Cal Poly, Team S16-G4, Livingston Spring 2018 Membro de Cal Poly, Team S16-G4, Livingston Spring 2018
CPSU-LIVINGSTON-S18S16G4
Membros da 4
Autoria de 10 guias
2 comentários
Are there any procedures required after either battery replacement or motherboard replacement? Re-loading of firmware, initialization, etc. Does the printer's serial number change as a result of battery replacement or motherboard replacement?
Erik Fjerstad - Responder
Bonjour ,
ma batterie est ok , par contre la courroie s'effiloche.
Peut on la remplacer et si oui comment y accéder?
J'ai déplacé le tendeur pour augmenter la tension de la courroie mais ce n'est pas suffisant.
Merci
BàV phil
Philippe Herbots - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 8
Últimos 7 dias: 28
Últimos 30 dias: 102
Duração total: 5,041
