Ir para o conteúdo principal
HP Officejet Pro 6835 Speaker Replacement
O que você precisa
  1. HP Officejet Pro 6835 Speaker Replacement, HP Officejet Pro 6835 Cover Disassembly: passo 1, imagem 1 %32
    • Open the main lid as far as it will go.
    • Use a plastic opening tool to gently pry off the hinge on the right side by pushing it to the left and off the hook.
    • Open the lid further.
  2. HP Officejet Pro 6835 Speaker Replacement: passo 2, imagem 1 %32 HP Officejet Pro 6835 Speaker Replacement: passo 2, imagem 2 %32 HP Officejet Pro 6835 Speaker Replacement: passo 2, imagem 3 %32
    • Use a T9 torx screwdriver to remove a total of ten (10) 12mm screws from the main cover by turning the screwdriver counterclockwise.
    • The two screws above the screen assembly are deep so you may need a long screwdriver.
  3. HP Officejet Pro 6835 Speaker Replacement: passo 3, imagem 1 %32
    • Grab the main cover and lift it up slightly.
    • Do not pull too hard—there is a cable connecting the cover to the printer.
  4. HP Officejet Pro 6835 Speaker Replacement: passo 4, imagem 1 %32 HP Officejet Pro 6835 Speaker Replacement: passo 4, imagem 2 %32
    • Grab the base of the white ribbon cable connecting the cover to the base of the printer and pull it out.
  5. HP Officejet Pro 6835 Speaker Replacement, Speaker: passo 5, imagem 1 %32 HP Officejet Pro 6835 Speaker Replacement, Speaker: passo 5, imagem 2 %32 HP Officejet Pro 6835 Speaker Replacement, Speaker: passo 5, imagem 3 %32
    • Grab the intertwined red and black wires. Gently pull up and disconnect the wires from the motherboard.
    • Be careful to remove the wires from the socket, NOT the socket from the board.
  6. HP Officejet Pro 6835 Speaker Replacement: passo 6, imagem 1 %32
    • Carefully slide the speaker out of the printer.
Conclusão
David J
Membro desde: 01/24/18
169 Reputação
Autoria de 2 guias
Equipe
Cal Poly, Team S2-G4, Livingston Winter 2018 Membro de Cal Poly, Team S2-G4, Livingston Winter 2018
CPSU-LIVINGSTON-W18S2G4
Membros da 4
Autoria de 16 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 4
Duração total: 263
