Ir para o conteúdo principal
HP Officejet J4550 All-in-one Glass Plate Replacement
O que você precisa
  1. HP Officejet J4550 All-in-one Glass Plate Replacement, Glass Plate: passo 1, imagem 1 %32 HP Officejet J4550 All-in-one Glass Plate Replacement, Glass Plate: passo 1, imagem 2 %32
    • Insert 2 fingers in the dent on the right side of the printer and pull towards the front of the printer.
    • Using fingers to open the cover of the scanner which located on the top of the printer.
  2. HP Officejet J4550 All-in-one Glass Plate Replacement: passo 2, imagem 1 %32 HP Officejet J4550 All-in-one Glass Plate Replacement: passo 2, imagem 2 %32 HP Officejet J4550 All-in-one Glass Plate Replacement: passo 2, imagem 3 %32
    • Remove four 10mm screws on the panel with T8 torx security screwdriver.
    • Remove the cover of the top part.
  3. HP Officejet J4550 All-in-one Glass Plate Replacement: passo 3, imagem 1 %32 HP Officejet J4550 All-in-one Glass Plate Replacement: passo 3, imagem 2 %32 HP Officejet J4550 All-in-one Glass Plate Replacement: passo 3, imagem 3 %32
    • Remove eight 10mm screws on the back of the controlling keyboard with T8 torx security screwdriver.
    • Remove the back board of the controlling keyboard.
  4. HP Officejet J4550 All-in-one Glass Plate Replacement: passo 4, imagem 1 %32 HP Officejet J4550 All-in-one Glass Plate Replacement: passo 4, imagem 2 %32
    • Remove the controlling keyboard with hands.
  5. HP Officejet J4550 All-in-one Glass Plate Replacement: passo 5, imagem 1 %32 HP Officejet J4550 All-in-one Glass Plate Replacement: passo 5, imagem 2 %32
    • Using fingers to open the back cover board of the glass plate.
  6. HP Officejet J4550 All-in-one Glass Plate Replacement: passo 6, imagem 1 %32 HP Officejet J4550 All-in-one Glass Plate Replacement: passo 6, imagem 2 %32 HP Officejet J4550 All-in-one Glass Plate Replacement: passo 6, imagem 3 %32
    • Remove the 10mm screw on the right of the board with T8 torx security screwdriver.
    • Remove the part that is under the 10mm screw.
  7. HP Officejet J4550 All-in-one Glass Plate Replacement: passo 7, imagem 1 %32 HP Officejet J4550 All-in-one Glass Plate Replacement: passo 7, imagem 2 %32
    • Remove the glass plate with hands.
Conclusão
Jiayin Zhu
Membro desde: 10/21/18
349 Reputação
Autoria de 3 guias
Equipe
UC Davis, Team S11-G8, Lore Fall 2018 Membro de UC Davis, Team S11-G8, Lore Fall 2018
UCD-LORE-F18S11G8
Membros da 3
Autoria de 8 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 11
Duração total: 180
