Ir para o conteúdo principal
HP Officejet J4550 All-in-one Button Replacement
O que você precisa
  1. HP Officejet J4550 All-in-one Button Replacement, Button: passo 1, imagem 1 %32 HP Officejet J4550 All-in-one Button Replacement, Button: passo 1, imagem 2 %32
    • Insert 2 fingers in the dent on the right side of the printer and pull towards the front of the printer.
    • Using fingers to open the cover of the scanner which located on the top of the printer.
  2. HP Officejet J4550 All-in-one Button Replacement: passo 2, imagem 1 %32 HP Officejet J4550 All-in-one Button Replacement: passo 2, imagem 2 %32 HP Officejet J4550 All-in-one Button Replacement: passo 2, imagem 3 %32
    • Remove four 10mm screws on the panel with T8 torx security screwdriver.
    • Remove the cover of the top part.
  3. HP Officejet J4550 All-in-one Button Replacement: passo 3, imagem 1 %32 HP Officejet J4550 All-in-one Button Replacement: passo 3, imagem 2 %32 HP Officejet J4550 All-in-one Button Replacement: passo 3, imagem 3 %32
    • Remove eight 10mm screws on the back of the controlling keyboard with T8 torx security screwdriver.
    • Remove the back board of the controlling keyboard.
  4. HP Officejet J4550 All-in-one Button Replacement: passo 4, imagem 1 %32 HP Officejet J4550 All-in-one Button Replacement: passo 4, imagem 2 %32 HP Officejet J4550 All-in-one Button Replacement: passo 4, imagem 3 %32
    • Remove the button that is located at the left of the controlling keyboard.
Conclusão
Jiayin Zhu
Membro desde: 10/21/18
349 Reputação
Autoria de 3 guias
Equipe
UC Davis, Team S11-G8, Lore Fall 2018 Membro de UC Davis, Team S11-G8, Lore Fall 2018
UCD-LORE-F18S11G8
Membros da 3
Autoria de 8 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 12
Duração total: 224
