Ir para o conteúdo principal
HP Officejet J3680 Phone Cord Replacement
O que você precisa
  1. HP Officejet J3680 Phone Cord Replacement, Unplug phone cord from handset: passo 1, imagem 1 %32
    • Unplug one end of the cord by squeezing the plastic piece and pulling it out from the handset as shown on the left.
  2. HP Officejet J3680 Phone Cord Replacement, Unplug phone cord from back of device: passo 2, imagem 1 %32
    • Turn the device over to see the bottom as shown on the left.
    • First, slide the cord out from under the plastic clip.
    • Then as done in step one, squeeze the plastic piece to remove it from the back of the device.
Conclusão
To reassemble your device, follow these instructions in reverse order. You will know the plastic piece has been inserted correctly if you hear it click into place.
Marisa
Membro desde: 10/22/14
206 Reputação
Autoria de 2 guias
Equipe
UMass Dartmouth, Team 1-1, Duarte Fall 2014 Membro de UMass Dartmouth, Team 1-1, Duarte Fall 2014
UMASSD-DUARTE-F14S1G1
Membros da 4
Autoria de 12 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 14
Duração total: 245
