Ir para o conteúdo principal
HP Officejet 4630 Scanner Head Replacement
O que você precisa
  1. HP Officejet 4630 Scanner Head Replacement, LCD Display: passo 1, imagem 1 %32 HP Officejet 4630 Scanner Head Replacement, LCD Display: passo 1, imagem 2 %32 HP Officejet 4630 Scanner Head Replacement, LCD Display: passo 1, imagem 3 %32
    • There is a hidden screw underneath the model sticker on the front panel.
    • Peel the model sticker off the cover.
    • This will expose the T10 screw securing the panel.
  2. HP Officejet 4630 Scanner Head Replacement: passo 2, imagem 1 %32 HP Officejet 4630 Scanner Head Replacement: passo 2, imagem 2 %32 HP Officejet 4630 Scanner Head Replacement: passo 2, imagem 3 %32
    • Remove the single 12mm-T10 screw securing the front panel to the printer body.
    • Loosen the panel cover from the printer body.
    • There is a ribbon cable connected to the backside of the cover. Disconnect the cable before separating the panel completely.
  3. HP Officejet 4630 Scanner Head Replacement: passo 3, imagem 1 %32 HP Officejet 4630 Scanner Head Replacement: passo 3, imagem 2 %32 HP Officejet 4630 Scanner Head Replacement: passo 3, imagem 3 %32
    • Gently remove the No-Fuss ribbon cable from the front panel.
  4. HP Officejet 4630 Scanner Head Replacement: passo 4, imagem 1 %32 HP Officejet 4630 Scanner Head Replacement: passo 4, imagem 2 %32 HP Officejet 4630 Scanner Head Replacement: passo 4, imagem 3 %32
    • Remove the seven 8mm screws using the Torx T6 screwdriver.
    • Remove the motherboard from the front-panel housing.
    • The LCD display is on the opposite side.
  5. HP Officejet 4630 Scanner Head Replacement, Power Supply: passo 5, imagem 1 %32 HP Officejet 4630 Scanner Head Replacement, Power Supply: passo 5, imagem 2 %32 HP Officejet 4630 Scanner Head Replacement, Power Supply: passo 5, imagem 3 %32
    • Lift the hood of the printer.
  6. HP Officejet 4630 Scanner Head Replacement: passo 6, imagem 1 %32 HP Officejet 4630 Scanner Head Replacement: passo 6, imagem 2 %32 HP Officejet 4630 Scanner Head Replacement: passo 6, imagem 3 %32
    • Remove the two T10 11mm screws.
  7. HP Officejet 4630 Scanner Head Replacement: passo 7, imagem 1 %32 HP Officejet 4630 Scanner Head Replacement: passo 7, imagem 2 %32 HP Officejet 4630 Scanner Head Replacement: passo 7, imagem 3 %32
    • Remove the panels covering the power brick and cord.
  8. HP Officejet 4630 Scanner Head Replacement: passo 8, imagem 1 %32 HP Officejet 4630 Scanner Head Replacement: passo 8, imagem 2 %32
    • Remove the cord from the power supply.
  9. HP Officejet 4630 Scanner Head Replacement: passo 9, imagem 1 %32 HP Officejet 4630 Scanner Head Replacement: passo 9, imagem 2 %32 HP Officejet 4630 Scanner Head Replacement: passo 9, imagem 3 %32
    • Slide the power supply out from the chassis.
    • The power supply is still attached; don't pull too quickly.
  10. HP Officejet 4630 Scanner Head Replacement: passo 10, imagem 1 %32
    • Remove final cable from power supply.
  11. HP Officejet 4630 Scanner Head Replacement, Scanner Head: passo 11, imagem 1 %32
    • Remove eight T10 1mm screws from the top hood of the printer.
  12. HP Officejet 4630 Scanner Head Replacement: passo 12, imagem 1 %32 HP Officejet 4630 Scanner Head Replacement: passo 12, imagem 2 %32 HP Officejet 4630 Scanner Head Replacement: passo 12, imagem 3 %32
    • Use the nylon spudger to pry the tab.
    • Lift up the entire panel.
  13. HP Officejet 4630 Scanner Head Replacement: passo 13, imagem 1 %32 HP Officejet 4630 Scanner Head Replacement: passo 13, imagem 2 %32 HP Officejet 4630 Scanner Head Replacement: passo 13, imagem 3 %32
    • Lift and flip the entire panel.
    • Be aware of the scanner head attached to the panel.
  14. HP Officejet 4630 Scanner Head Replacement: passo 14, imagem 1 %32 HP Officejet 4630 Scanner Head Replacement: passo 14, imagem 2 %32 HP Officejet 4630 Scanner Head Replacement: passo 14, imagem 3 %32
    • Start with the scanner head in place.
    • Unwind the ribbon from the track.
    • Detach ribbon completely.
Conclusão
Maya Willis
Membro desde: 01/24/18
415 Reputação
Autoria de 3 guias
Equipe
Cal Poly, Team S18-G3, Livingston Winter 2018 Membro de Cal Poly, Team S18-G3, Livingston Winter 2018
CPSU-LIVINGSTON-W18S18G3
Membros da 4
Autoria de 18 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 14
Duração total: 1,393
