Ir para o conteúdo principal
HP Officejet 4630 Paper Tray Replacement
O que você precisa
  1. HP Officejet 4630 Paper Tray Replacement, Paper Tray: passo 1, imagem 1 %32
    • Begin by turning your printer upside down.
    • It can be helpful to position an object beneath the printer to keep it level while you work on it.
  2. HP Officejet 4630 Paper Tray Replacement: passo 2, imagem 1 %32
    • Use the T-10 screwdriver to remove the two 11-mm screws.
  3. HP Officejet 4630 Paper Tray Replacement: passo 3, imagem 1 %32
    • Pull the paper tray out until it hits the stops on either side of the tray.
  4. HP Officejet 4630 Paper Tray Replacement: passo 4, imagem 1 %32 HP Officejet 4630 Paper Tray Replacement: passo 4, imagem 2 %32 HP Officejet 4630 Paper Tray Replacement: passo 4, imagem 3 %32
    • Lift up on one side of the black plastic bar with one hand while pulling the paper tray out of the printer with your other hand.
    • The side of the tray should slide away from the printer a little bit.
  5. HP Officejet 4630 Paper Tray Replacement: passo 5, imagem 1 %32 HP Officejet 4630 Paper Tray Replacement: passo 5, imagem 2 %32
    • Repeat the previous step but for the other side of the tray.
  6. HP Officejet 4630 Paper Tray Replacement: passo 6, imagem 1 %32
    • The paper tray should now be free to slide away from the printer.
Conclusão
5 outras pessoas executaram este guia.
Tyler Allen
Membro desde: 01/24/18
513 Reputação
Autoria de 2 guias
Equipe
Cal Poly, Team S18-G3, Livingston Winter 2018 Membro de Cal Poly, Team S18-G3, Livingston Winter 2018
CPSU-LIVINGSTON-W18S18G3
4 Membros
Autoria de 18 guias
1Comentário do guia
merci pour l info!
devaux - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 12
Últimos 30 dias: 41
Ao todo: 2,352
