Ir para o conteúdo principal
HP OfficeJet 4650 Paper Tray Replacement
O que você precisa
  1. HP OfficeJet 4650 Paper Tray Replacement, Paper Tray: passo 1, imagem 1 %32 HP OfficeJet 4650 Paper Tray Replacement, Paper Tray: passo 1, imagem 2 %32
    • Use two hands to carefully flip the printer upside down.
    • Remove the ten 14mm screws by using a 2.0 mm hex screwdriver and turning the screws counterclockwise.
  2. HP OfficeJet 4650 Paper Tray Replacement: passo 2, imagem 1 %32 HP OfficeJet 4650 Paper Tray Replacement: passo 2, imagem 2 %32
    • Lift the left and right side flaps away from the paper tray to remove them.
  3. HP OfficeJet 4650 Paper Tray Replacement: passo 3, imagem 1 %32 HP OfficeJet 4650 Paper Tray Replacement: passo 3, imagem 2 %32 HP OfficeJet 4650 Paper Tray Replacement: passo 3, imagem 3 %32
    • Remove the left spring by grabbing the rubber tips connected to the spring and lifting up.
  4. HP OfficeJet 4650 Paper Tray Replacement: passo 4, imagem 1 %32 HP OfficeJet 4650 Paper Tray Replacement: passo 4, imagem 2 %32
    • Remove the right spring by grabbing the rubber tips connected to the spring and lifting up.
  5. HP OfficeJet 4650 Paper Tray Replacement: passo 5, imagem 1 %32
    • Remove the paper tray by pulling the tray away from the printer.
Conclusão
Uma outra pessoa concluiu este guia.
Equipe
Cal Poly, Team S19-G6, Livingston Winter 2018 Membro de Cal Poly, Team S19-G6, Livingston Winter 2018
CPSU-LIVINGSTON-W18S19G6
Membros da 3
Autoria de 10 guias
3 comentários
Thank you Stephanie from a clumsy nearly 80yr old who had pulled the tray right out! A very clear guide to a simple job I had not got a clue how to do. Stay virus free and prosper. JG (UK)
John G - Responder
Any ideas where a aperson could order a replacement paper tray like this one? (For an HP OfficeJet 4650 model?
suemouthey - Responder
I broke the back of the paper tray so my printer continually says to add paper. Where can I buy another paper tray without having to buy a brand new printer?
Jacquie - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 26
Duração total: 4,661
