Ir para o conteúdo principal
HP OfficeJet 4650 Manual One-Inch Paper-Feed Roller Replacement
O que você precisa
  1. HP OfficeJet 4650 Manual One-Inch Paper-Feed Roller Replacement, Manual One-Inch Paper-Feed Roller: passo 1, imagem 1 %32 HP OfficeJet 4650 Manual One-Inch Paper-Feed Roller Replacement, Manual One-Inch Paper-Feed Roller: passo 1, imagem 2 %32
    • Open the document feeder cover by flipping it to the left with the front panel facing you.
    • The document feeder is designed to be a bit more difficult to open, so it is okay to use a little more force.
  2. HP OfficeJet 4650 Manual One-Inch Paper-Feed Roller Replacement: passo 2, imagem 1 %32 HP OfficeJet 4650 Manual One-Inch Paper-Feed Roller Replacement: passo 2, imagem 2 %32 HP OfficeJet 4650 Manual One-Inch Paper-Feed Roller Replacement: passo 2, imagem 3 %32
    • Locate the manual one-inch paper-feed roller end of the document feeder cover.
    • Remove the 11.0mm screw on the side of the roller with 2.0mm hex screwdriver.
  3. HP OfficeJet 4650 Manual One-Inch Paper-Feed Roller Replacement: passo 3, imagem 1 %32 HP OfficeJet 4650 Manual One-Inch Paper-Feed Roller Replacement: passo 3, imagem 2 %32 HP OfficeJet 4650 Manual One-Inch Paper-Feed Roller Replacement: passo 3, imagem 3 %32
    • Pull the side cover of the manual one-inch paper-feed roller to the right and remove the paper roller.
Conclusão
Equipe
Cal Poly, Team S19-G6, Livingston Winter 2018 Membro de Cal Poly, Team S19-G6, Livingston Winter 2018
CPSU-LIVINGSTON-W18S19G6
3 Membros
Autoria de 10 guias
0 comentários
Comentar
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 10
Últimos 30 dias: 30
Ao todo: 1,832
