Introdução
This guide will help assist you in replacing the RAM component in your laptop. Use this guide if HP Notebook 15-ba018ds is having low storage space. Beware of all the wires that may get damaged during this process.
O que você precisa
Flip the laptop over so the battery is exposed which will be next to the hinges on the top left and right.
Unscrew the 8 screws on the back cover.
There are also two screws in the battery area that you unscrew.
3 outras pessoas executaram este guia.
