Ir para o conteúdo principal
HP Mobile Thin Client mt41 Optical Disc Drive Replacement
O que você precisa
  1. HP Mobile Thin Client mt41 Optical Disc Drive Replacement, Optical Disc Drive: passo 1, imagem 1 %32 HP Mobile Thin Client mt41 Optical Disc Drive Replacement, Optical Disc Drive: passo 1, imagem 2 %32
    • Turn off and unplug your laptop. Also, make sure to disconnect all the external devices.
    • After that, slide the two switches to the indicated directions in order to remove the battery and the back cover.
  2. HP Mobile Thin Client mt41 Optical Disc Drive Replacement: passo 2, imagem 1 %32 HP Mobile Thin Client mt41 Optical Disc Drive Replacement: passo 2, imagem 2 %32
    • Now you're able to remove the battery and the service cover.
    • Slide the battery upward to remove it.
  3. HP Mobile Thin Client mt41 Optical Disc Drive Replacement: passo 3, imagem 1 %32 HP Mobile Thin Client mt41 Optical Disc Drive Replacement: passo 3, imagem 2 %32 HP Mobile Thin Client mt41 Optical Disc Drive Replacement: passo 3, imagem 3 %32
    • Slide the service cover downward.
    • After that, lift the back cover to remove it.
  4. HP Mobile Thin Client mt41 Optical Disc Drive Replacement: passo 4, imagem 1 %32 HP Mobile Thin Client mt41 Optical Disc Drive Replacement: passo 4, imagem 2 %32 HP Mobile Thin Client mt41 Optical Disc Drive Replacement: passo 4, imagem 3 %32
    • Unlock the indicated screw in order to remove the optical drive.
    • Slide the optical drive to completely remove it from the laptop.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 3
Duração total: 425
