Ir para o conteúdo principal
HP Mobile Thin Client mt41 Fan Replacement
O que você precisa
  1. HP Mobile Thin Client mt41 Fan Replacement, Back Cover: passo 1, imagem 1 %32 HP Mobile Thin Client mt41 Fan Replacement, Back Cover: passo 1, imagem 2 %32
    • Remove the nine screws that keep the back cover secured using the T5 Torx screwdriver.
  2. HP Mobile Thin Client mt41 Fan Replacement: passo 2, imagem 1 %32 HP Mobile Thin Client mt41 Fan Replacement: passo 2, imagem 2 %32
    • Remove the middle plate using the iFixit opening tool.
    • This may require a bit of force. If it is not coming out try the other side.
  3. HP Mobile Thin Client mt41 Fan Replacement: passo 3, imagem 1 %32
    • Pop the back cover off from its latches by separating the two parts along their seam using the iFixit opening tool.
    • Be gentle; the plastic can crack.
  4. HP Mobile Thin Client mt41 Fan Replacement: passo 4, imagem 1 %32
    • Lift the back cover once all corners are unclasped from their latches.
    • Lifting the cover should not require much force.
  5. HP Mobile Thin Client mt41 Fan Replacement, Fan: passo 5, imagem 1 %32 HP Mobile Thin Client mt41 Fan Replacement, Fan: passo 5, imagem 2 %32
    • Using a J1 head for your screwdriver, remove the 4 surrounding screws.
  6. HP Mobile Thin Client mt41 Fan Replacement: passo 6, imagem 1 %32
    • Keep your screws close by, and slowly remove the CPU fan.
  7. HP Mobile Thin Client mt41 Fan Replacement: passo 7, imagem 1 %32
    • Be mindful of wires, the final step is to unplug the fan from the motherboard, at the base of red and blue wires.
Conclusão
Uma outra pessoa concluiu este guia.
0 comentários
Comentar
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 7
Últimos 30 dias: 13
Ao todo: 439
