Ir para o conteúdo principal
Fix Your Stuff
Right to Repair
Parts & Tools
  1. Locate the screws highlighted to remove. We recommend removing the battery first. Refer to the "Battery Replacement" guide to learn how to remove the battery. We recommend removing the battery first. Refer to the "Battery Replacement" guide to learn how to remove the battery.
    • Locate the screws highlighted to remove.
    • We recommend removing the battery first. Refer to the "Battery Replacement" guide to learn how to remove the battery.
  2. Remove the middle back lid shown in the image. May require a bit of force. If it is not coming out try the other side.
    • Remove the middle back lid shown in the image.
    • May require a bit of force. If it is not coming out try the other side.
  3. Go around the edges with a special tool to pop lid out of place.
    • Go around the edges with a special tool to pop lid out of place.
  4. Once all corners are popped out of place lift the cover up slowly.
    • Once all corners are popped out of place lift the cover up slowly.
    • Lifting the lid should not require much force.
Conclusão
Raul Rodriguez
Membro desde: 27-02-2018
289 Reputation
3 Guias de autoria
Adicione um comentário
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 6
All Time: 114
