Introdução
The Real Time Clock (RTC) Battery helps to retain important BIOS settings such as system time, date, and BIOS configuration while the laptop is turned off or when the main battery is removed.
O que você precisa
Close the laptop and turn it over so that the underside is up and the silver battery bay is facing towards you.
