Introdução
In this guide you'll be able to locate and remove or change out the Wireless Card of the HP Mini 210-1199DX.
O que você precisa
Unplug the netbook.
Secure the netbook in a upright position.
Slide the plastic battery latch that secures it into the netbook.
Keep thumb secure on the right tab as you begin to remove the battery.
Press down on the two orange buttons to release.
If the case does not pop off, begin to use Spudger to pry the case off the back.
