Esta versão pode conter edições incorretas. Mude para o último instantâneo verificado.
O que você precisa
Este passo não foi traduzido. Ajude a traduzi-lo
Hold the netbook top-side down with the lid closed.
Slide the plastic battery release latches towards the lock symbols.
Turn the netbook to view its edge.
Press both orange eject buttons simultaneously, and use a spudger to pry off the back case.
Use the spudger to pry off the back case by the edge near the battery compartment, and work your way to the sides. The case will then pivot along the front edge.
Disconnect the two gold antenna cables from the WWAN card using a plastic opening tool.
Use a Phillips #00 screwdriver to remove the two Phillips 2.0 and 3.0 mm screws that secure the WWAN to the system board.
Remove the WWAN card by pulling the WWAN card out at an angle.
2 comentários
apakah benda tersebut ada dalam paket penjualan, atau dijual terpisah?
I wonder sims slot on hp mini and other major brands also. Toshiba ,Acer
