Este guia tem alterações mais recentes. Mudar para a última versão não verificada.
Introdução
Replacing the WWAN (Wireless Wide Area Network) card is easy and straightforward.
O que você precisa
Hold the netbook top-side down with the lid closed.
Slide the plastic battery release latches towards the lock symbols.
Turn the netbook to view its edge.
Press both orange eject buttons simultaneously, and use a spudger to pry off the back case.
Use a plastic opening tool to disconnect the two gold antenna cables from the WWAN card.
2 comentários
apakah benda tersebut ada dalam paket penjualan, atau dijual terpisah?
I wonder sims slot on hp mini and other major brands also. Toshiba ,Acer
