Este guia tem alterações mais recentes. Mudar para a última versão não verificada.
Introdução
This guide will show you how to install a keyboard from the backside of the netbook. You want to replace your keyboard if you are experiencing any keyboard malfunctions, such as a slow or non-existent response from the keyboard to the computer. The keyboard does not require too much disassembly of the laptop, and it should take no time at all to repair.
O que você precisa
Hold the netbook top-side down with the lid closed.
Slide the plastic battery release latches towards the lock symbols.
Turn the netbook to view its edge.
Press both orange eject buttons simultaneously, and use a spudger to pry off the back case.
Using a screwdriver, remove the three 6.6 mm screws highlighted with the red circles in the first picture above.
Lift the latch on the ZIF (zero insertion-force) connector using a plastic opening tool. The ZIF connector is located on the motherboard and is connected to the keyboard through the ribbon cable.
Disconnect the ribbon cable from the ZIF connector on the motherboard by lifting it up and out; this completely removes the keyboard.
11 outras pessoas executaram este guia.
