Introdução
This guide will teach you how to perform a fan replacement on the HP Mini 210.
O que você precisa
Hold the netbook top-side down with the lid closed.
Slide the plastic battery release latches towards the lock symbols.
Turn the netbook to view its edge.
Press both orange eject buttons simultaneously, and use a spudger to pry off the back case.
Using a screwdriver, remove the three 6.6 mm screws highlighted with the red circles in the first picture above.
Lift the latch on the ZIF (zero insertion-force) connector using a plastic opening tool. The ZIF connector is located on the motherboard and is connected to the keyboard through the ribbon cable.
Disconnect the ribbon cable from the ZIF connector on the motherboard by lifting it up and out; this completely removes the keyboard.
Use the spudger to peel the front black plastic plate from the rest of the case, starting at a corner and working your way around the entire case.
3 outras pessoas executaram este guia.
