Ir para o conteúdo principal
HP Mini 110-3735dx Screen Replacement
O que você precisa
  1. HP Mini 110-3735dx Screen Replacement, Battery: passo 1, imagem 1 %32 HP Mini 110-3735dx Screen Replacement, Battery: passo 1, imagem 2 %32 HP Mini 110-3735dx Screen Replacement, Battery: passo 1, imagem 3 %32
    • With the bottom of the HP Mini facing up, slide both switches inward towards each other.
  2. HP Mini 110-3735dx Screen Replacement: passo 2, imagem 1 %32 HP Mini 110-3735dx Screen Replacement: passo 2, imagem 2 %32
    • With the left switch still pushed inward, pull the battery towards you to remove it from the computer.
  3. HP Mini 110-3735dx Screen Replacement, Backcover: passo 3, imagem 1 %32 HP Mini 110-3735dx Screen Replacement, Backcover: passo 3, imagem 2 %32 HP Mini 110-3735dx Screen Replacement, Backcover: passo 3, imagem 3 %32
    • Pull upward from under the back cover via the missing battery area.
    • Best to start from one of the corners.
  4. HP Mini 110-3735dx Screen Replacement, Keyboard: passo 4, imagem 1 %32 HP Mini 110-3735dx Screen Replacement, Keyboard: passo 4, imagem 2 %32
    • Remove the three 4.0 mm screws with the keyboard indicator next to them using a Phillips #1 screw driver.
  5. HP Mini 110-3735dx Screen Replacement: passo 5, imagem 1 %32 HP Mini 110-3735dx Screen Replacement: passo 5, imagem 2 %32
    • Flip the laptop over, and open it up.
    • Don't worry! No pieces will fall out.
  6. HP Mini 110-3735dx Screen Replacement: passo 6, imagem 1 %32 HP Mini 110-3735dx Screen Replacement: passo 6, imagem 2 %32
    • With the keyboard facing you, pull the black bezel upward until its loose.
    • You should hear three clicks.
  7. HP Mini 110-3735dx Screen Replacement: passo 7, imagem 1 %32 HP Mini 110-3735dx Screen Replacement: passo 7, imagem 2 %32
    • Move and hold the bezel slightly towards the screen while lifting the keyboard from the top.
  8. HP Mini 110-3735dx Screen Replacement: passo 8, imagem 1 %32
    • Pull up the keyboard from the bottom corners exposing the keyboard cable.
  9. HP Mini 110-3735dx Screen Replacement: passo 9, imagem 1 %32 HP Mini 110-3735dx Screen Replacement: passo 9, imagem 2 %32
    • Lift the black holder connected to the keyboard cable until it points up.
  10. HP Mini 110-3735dx Screen Replacement: passo 10, imagem 1 %32 HP Mini 110-3735dx Screen Replacement: passo 10, imagem 2 %32
    • Gently pull the keyboard cable from the socket.
  11. HP Mini 110-3735dx Screen Replacement, Hard Drive Cage: passo 11, imagem 1 %32
    • Remove the three 5.0 mm screws holding the hard drive cage in place using a Phillips #1 screw driver.
  12. HP Mini 110-3735dx Screen Replacement: passo 12, imagem 1 %32 HP Mini 110-3735dx Screen Replacement: passo 12, imagem 2 %32 HP Mini 110-3735dx Screen Replacement: passo 12, imagem 3 %32
    • Lift the hard drive cage by pulling the tape upward.
    • Start by pulling the tape from the side with the keyboard symbol.
  13. HP Mini 110-3735dx Screen Replacement: passo 13, imagem 1 %32 HP Mini 110-3735dx Screen Replacement: passo 13, imagem 2 %32
    • Unplug the cable connecting to the hard drive.
  14. HP Mini 110-3735dx Screen Replacement, Screen: passo 14, imagem 1 %32 HP Mini 110-3735dx Screen Replacement, Screen: passo 14, imagem 2 %32
    • Remove the 8 5.0 mm screws under the keyboard using a Phillips #1 screw driver.
  15. HP Mini 110-3735dx Screen Replacement: passo 15, imagem 1 %32 HP Mini 110-3735dx Screen Replacement: passo 15, imagem 2 %32 HP Mini 110-3735dx Screen Replacement: passo 15, imagem 3 %32
    • Lift the two black holders upward located next to the socket for the keyboard close to the tracked pad.
  16. HP Mini 110-3735dx Screen Replacement: passo 16, imagem 1 %32 HP Mini 110-3735dx Screen Replacement: passo 16, imagem 2 %32
    • Remove the two connectors for the motherboard from their sockets.
  17. HP Mini 110-3735dx Screen Replacement: passo 17, imagem 1 %32 HP Mini 110-3735dx Screen Replacement: passo 17, imagem 2 %32
    • Close the laptop by bringing the screen down.
    • Flip the laptop over to the other side.
  18. HP Mini 110-3735dx Screen Replacement: passo 18, imagem 1 %32 HP Mini 110-3735dx Screen Replacement: passo 18, imagem 2 %32
    • Remove the 6 5.0 mm screws holding the back plate together using a Phillips #1 screw driver.
  19. HP Mini 110-3735dx Screen Replacement: passo 19, imagem 1 %32 HP Mini 110-3735dx Screen Replacement: passo 19, imagem 2 %32
    • Remove the 2 3.0 mm screw head holding the plastic piece in place using a Phillips #1 screw driver.
    • Located on the left and right side where the battery was removed.
  20. HP Mini 110-3735dx Screen Replacement: passo 20, imagem 1 %32 HP Mini 110-3735dx Screen Replacement: passo 20, imagem 2 %32 HP Mini 110-3735dx Screen Replacement: passo 20, imagem 3 %32
    • Pull the black plastic pieces that the screws was holding inward.
    • The pieces are located on the left and right corners connecting the bottom and top of the HP Mini.
  21. HP Mini 110-3735dx Screen Replacement: passo 21, imagem 1 %32 HP Mini 110-3735dx Screen Replacement: passo 21, imagem 2 %32
    • Flip the laptop back over.
    • Open it by lifting the screeen.
  22. HP Mini 110-3735dx Screen Replacement: passo 22, imagem 1 %32 HP Mini 110-3735dx Screen Replacement: passo 22, imagem 2 %32 HP Mini 110-3735dx Screen Replacement: passo 22, imagem 3 %32
    • Right next to the previous plastic piece, remove the other two plastic pieces.
    • This may be difficult to come off. Tilt the screen back and forth to help loosen the piece.
  23. HP Mini 110-3735dx Screen Replacement: passo 23, imagem 1 %32
    • Using the plastic prying tool, pry the front plate of the bottom part of your HP Mini.
    • Start along the speaker grill near the touch pad, and move along the sides.
  24. HP Mini 110-3735dx Screen Replacement: passo 24, imagem 1 %32 HP Mini 110-3735dx Screen Replacement: passo 24, imagem 2 %32
    • Lift up the front plate where the keyboard was.
  25. HP Mini 110-3735dx Screen Replacement: passo 25, imagem 1 %32 HP Mini 110-3735dx Screen Replacement: passo 25, imagem 2 %32 HP Mini 110-3735dx Screen Replacement: passo 25, imagem 3 %32
    • Remove the display cable from the motherboard located on the top left corner under where the keyboard was by pulling on the black tab.
    • Move the cable.
  26. HP Mini 110-3735dx Screen Replacement: passo 26, imagem 1 %32 HP Mini 110-3735dx Screen Replacement: passo 26, imagem 2 %32 HP Mini 110-3735dx Screen Replacement: passo 26, imagem 3 %32
    • Remove the webcam cables from the motherboard.
    • Located on the back side of the laptop in the bottom left corner.
  27. HP Mini 110-3735dx Screen Replacement: passo 27, imagem 1 %32
    • Flip over the computer, and open the laptop.
    • Lift up the front plate on the top right corner.
  28. HP Mini 110-3735dx Screen Replacement: passo 28, imagem 1 %32 HP Mini 110-3735dx Screen Replacement: passo 28, imagem 2 %32 HP Mini 110-3735dx Screen Replacement: passo 28, imagem 3 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Pull the cables for the web cam out using tweezers.
  29. HP Mini 110-3735dx Screen Replacement: passo 29, imagem 1 %32 HP Mini 110-3735dx Screen Replacement: passo 29, imagem 2 %32
    • Remove the 2 3.0 mm screws on both sides of the bottom of the display using a Phillips #1 screwdriver.
  30. HP Mini 110-3735dx Screen Replacement: passo 30, imagem 1 %32 HP Mini 110-3735dx Screen Replacement: passo 30, imagem 2 %32
    • Remove the black plastic piece that the screw was holding on both sides.
    • This will reveal another screw.
  31. HP Mini 110-3735dx Screen Replacement: passo 31, imagem 1 %32 HP Mini 110-3735dx Screen Replacement: passo 31, imagem 2 %32
    • Remove the 2 3.0 mm screws on both sides using a Phillips #1 screw driver.
    • When removing, keep hold of the screen to make sure it doesn't fall.
  32. HP Mini 110-3735dx Screen Replacement: passo 32, imagem 1 %32
    • Pry the front plate using the plastic opening tool by pushing along the border of the front and back plate.
    • Make sure to pry from the sides, top and bottom as the corners will come undone themselves.
  33. HP Mini 110-3735dx Screen Replacement: passo 33, imagem 1 %32 HP Mini 110-3735dx Screen Replacement: passo 33, imagem 2 %32 HP Mini 110-3735dx Screen Replacement: passo 33, imagem 3 %32
    • Remove the front plate.
    • Pull the cables through the holes.
  34. HP Mini 110-3735dx Screen Replacement: passo 34, imagem 1 %32 HP Mini 110-3735dx Screen Replacement: passo 34, imagem 2 %32
    • Remove the 4 4.0 mm screws holding the screen in place using a Phillips #1 screw driver.
  35. HP Mini 110-3735dx Screen Replacement: passo 35, imagem 1 %32 HP Mini 110-3735dx Screen Replacement: passo 35, imagem 2 %32
    • Lift the screen up.
  36. HP Mini 110-3735dx Screen Replacement: passo 36, imagem 1 %32 HP Mini 110-3735dx Screen Replacement: passo 36, imagem 2 %32
    • Under the screen, peel off the tape near the cable completely, so you can see the socket for the cable.
Conclusão
Tyrone Williams
Membro desde: 03/10/16
905 Reputação
Autoria de 7 guias
Equipe
UMass Dartmouth, Team 4-1, Catania Spring 2016 Membro de UMass Dartmouth, Team 4-1, Catania Spring 2016
UMASSD-CATANIA-S16S4G1
Membros da 4
Autoria de 7 guias
Um comentário
Tengo una pregunta en pantalla habrá alguna otra que sea compatible con esta hp sin ser el mismo modelo?
Icela Ross - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 14
Duração total: 787
