Ir para o conteúdo principal
HP Mini 110-3735dx Hard Drive Replacement
O que você precisa
  1. HP Mini 110-3735dx Hard Drive Replacement, Battery: passo 1, imagem 1 %32 HP Mini 110-3735dx Hard Drive Replacement, Battery: passo 1, imagem 2 %32 HP Mini 110-3735dx Hard Drive Replacement, Battery: passo 1, imagem 3 %32
    • With the bottom of the HP Mini facing up, slide both switches inward towards each other.
  2. HP Mini 110-3735dx Hard Drive Replacement: passo 2, imagem 1 %32 HP Mini 110-3735dx Hard Drive Replacement: passo 2, imagem 2 %32
    • With the left switch still pushed inward, pull the battery towards you to remove it from the computer.
  3. HP Mini 110-3735dx Hard Drive Replacement, Backcover: passo 3, imagem 1 %32 HP Mini 110-3735dx Hard Drive Replacement, Backcover: passo 3, imagem 2 %32 HP Mini 110-3735dx Hard Drive Replacement, Backcover: passo 3, imagem 3 %32
    • Pull upward from under the back cover via the missing battery area.
    • Best to start from one of the corners.
  4. HP Mini 110-3735dx Hard Drive Replacement, Hard Drive Cage: passo 4, imagem 1 %32
    • Remove the three 5.0 mm screws holding the hard drive cage in place using a Phillips #1 screw driver.
  5. HP Mini 110-3735dx Hard Drive Replacement: passo 5, imagem 1 %32 HP Mini 110-3735dx Hard Drive Replacement: passo 5, imagem 2 %32 HP Mini 110-3735dx Hard Drive Replacement: passo 5, imagem 3 %32
    • Lift the hard drive cage by pulling the tape upward.
    • Start by pulling the tape from the side with the keyboard symbol.
  6. HP Mini 110-3735dx Hard Drive Replacement: passo 6, imagem 1 %32 HP Mini 110-3735dx Hard Drive Replacement: passo 6, imagem 2 %32
    • Unplug the cable connecting to the hard drive.
  7. HP Mini 110-3735dx Hard Drive Replacement, Hard Drive: passo 7, imagem 1 %32 HP Mini 110-3735dx Hard Drive Replacement, Hard Drive: passo 7, imagem 2 %32 HP Mini 110-3735dx Hard Drive Replacement, Hard Drive: passo 7, imagem 3 %32
    • Remove the four 4.0 mm screws on both sides of the cage using a Phillips #1 screw driver.
  8. HP Mini 110-3735dx Hard Drive Replacement: passo 8, imagem 1 %32 HP Mini 110-3735dx Hard Drive Replacement: passo 8, imagem 2 %32 HP Mini 110-3735dx Hard Drive Replacement: passo 8, imagem 3 %32
    • Gently remove the hard drive from it's cage.
Conclusão
Uma outra pessoa concluiu este guia.
Tyrone Williams
Membro desde: 03/10/16
905 Reputação
Autoria de 7 guias
Equipe
UMass Dartmouth, Team 4-1, Catania Spring 2016 Membro de UMass Dartmouth, Team 4-1, Catania Spring 2016
UMASSD-CATANIA-S16S4G1
Membros da 4
Autoria de 7 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 9
Duração total: 620
