Ir para o conteúdo principal
HP Mini 110-3131dx Memory Card Replacement
O que você precisa
    • Power off the laptop before trying to remove the battery.
    • Turn the laptop upside down, and locate the sliding tabs on the battery.
    • Slide both tabs in an inward direction, then slide the battery away from the laptop.
  1. HP Mini 110-3131dx Memory Card Replacement, Back Cover: passo 2, imagem 1 %32 HP Mini 110-3131dx Memory Card Replacement, Back Cover: passo 2, imagem 2 %32
    • To remove the bottom cover pull the orange tab to the right until it clicks.
    • Carefully disconnect the clips as you lift the bottom cover.
  2. HP Mini 110-3131dx Memory Card Replacement, Memory Card: passo 3, imagem 1 %32 HP Mini 110-3131dx Memory Card Replacement, Memory Card: passo 3, imagem 2 %32 HP Mini 110-3131dx Memory Card Replacement, Memory Card: passo 3, imagem 3 %32
    • Find the two silver screws that hold the memory card cover.
    • Take a PH1 screwdriver and unscrew the two screws.
    • Remove the metal cover
  3. HP Mini 110-3131dx Memory Card Replacement: passo 4, imagem 1 %32 HP Mini 110-3131dx Memory Card Replacement: passo 4, imagem 2 %32
    • Pull the two white tabs located on either side of the memory card away from each other until the card pops up
    • Remove the card
Conclusão
To install the new memory card, follow these instructions in reverse order.
Uma outra pessoa concluiu este guia.
aarondcollege
Membro desde: 10/06/16
1.297 Reputação
Autoria de 10 guias
Equipe
USF Tampa, Team 2-4, Cagle Fall 2016 Membro de USF Tampa, Team 2-4, Cagle Fall 2016
USFT-CAGLE-F16S2G4
Membros da 5
Autoria de 10 guias
Um comentário
what ram she using hp mini
ASKAR MALAYA - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 7
Últimos 30 dias: 18
Duração total: 689
