Ir para o conteúdo principal
HP Mini 110-3131dx Hard Drive Replacement
O que você precisa
    • Power off the laptop before trying to remove the battery.
    • Turn the laptop upside down, and locate the sliding tabs on the battery.
    • Slide both tabs in an inward direction, then slide the battery away from the laptop.
  1. HP Mini 110-3131dx Hard Drive Replacement, Back Cover: passo 2, imagem 1 %32 HP Mini 110-3131dx Hard Drive Replacement, Back Cover: passo 2, imagem 2 %32
    • To remove the bottom cover pull the orange tab to the right until it clicks.
    • Carefully disconnect the clips as you lift the bottom cover.
  2. HP Mini 110-3131dx Hard Drive Replacement, Hard Drive: passo 3, imagem 1 %32
    • Remove the four screws holding down the hard drive using a Phillips #1 screwdriver.
  3. HP Mini 110-3131dx Hard Drive Replacement: passo 4, imagem 1 %32 HP Mini 110-3131dx Hard Drive Replacement: passo 4, imagem 2 %32
    • Lift the black flap covering the hard drive then slide it towards the left using the orange tab until it's released from its receptacle.
    • Pull the hard drive out of the laptop.
    • Put the hard drive in an anti-static bag to decrease the likelihood of harming it with static electricity.
Conclusão
To reinstall a new or old hard drive, follow these instructions in reverse order.
3 outras pessoas executaram este guia.
aarondcollege
Membro desde: 10/06/16
1.297 Reputação
Autoria de 10 guias
Equipe
USF Tampa, Team 2-4, Cagle Fall 2016 Membro de USF Tampa, Team 2-4, Cagle Fall 2016
USFT-CAGLE-F16S2G4
Membros da 5
Autoria de 10 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 23
Duração total: 1,454
