Ir para o conteúdo principal
HP Mini 110-1046NR Memory Card Replacement
O que você precisa
  1. HP Mini 110-1046NR Memory Card Replacement, Battery: passo 1, imagem 1 %32 HP Mini 110-1046NR Memory Card Replacement, Battery: passo 1, imagem 2 %32 HP Mini 110-1046NR Memory Card Replacement, Battery: passo 1, imagem 3 %32
    • Power-off the netbook fully before attempting to remove the battery.
    • Flip your netbook upside down, and locate the sliding tabs near the battery.
    • Slide both tabs inward so that the battery visibly moves away from the case of the computer.
    • Release the tabs and pull the battery out.
  2. HP Mini 110-1046NR Memory Card Replacement, Memory Card Cover: passo 2, imagem 1 %32 HP Mini 110-1046NR Memory Card Replacement, Memory Card Cover: passo 2, imagem 2 %32 HP Mini 110-1046NR Memory Card Replacement, Memory Card Cover: passo 2, imagem 3 %32
    • Flip the netbook over so you are looking at the bottom, and locate the two screws that hold the memory card cover.
    • Next, take a Phillips PH1 screwdriver and unscrew the two screws.
    • These screws will not release from the cover once they are unscrewed.
    • If necessary, use the flat end of the spudger to assist in prying the cover away from the computer.
  3. HP Mini 110-1046NR Memory Card Replacement, Memory Card: passo 3, imagem 1 %32 HP Mini 110-1046NR Memory Card Replacement, Memory Card: passo 3, imagem 2 %32 HP Mini 110-1046NR Memory Card Replacement, Memory Card: passo 3, imagem 3 %32
    • Carefully push the clips to the side, away from the memory card.
    • Note: The memory module is spring-loaded and will pop out when the clips are detatched.
    • Slide the memory card straight out, holding it as shown to avoid getting skin oils on the electrical contacts.
Conclusão
Jared Cooper
Membro desde: 10/18/13
649 Reputação
Autoria de 5 guias
Equipe
Clemson, Team 14-1, Benson Fall 2013 Membro de Clemson, Team 14-1, Benson Fall 2013
CLEM-BENSON-F13S14G1
Membros da 3
Autoria de 12 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 6
Duração total: 1,321
