Ir para o conteúdo principal
HP Mini 110-1046NR Hard Drive Replacement
O que você precisa
  1. HP Mini 110-1046NR Hard Drive Replacement, Battery: passo 1, imagem 1 %32 HP Mini 110-1046NR Hard Drive Replacement, Battery: passo 1, imagem 2 %32 HP Mini 110-1046NR Hard Drive Replacement, Battery: passo 1, imagem 3 %32
    • Power-off the netbook fully before attempting to remove the battery.
    • Flip your netbook upside down, and locate the sliding tabs near the battery.
    • Slide both tabs inward so that the battery visibly moves away from the case of the computer.
    • Release the tabs and pull the battery out.
  2. HP Mini 110-1046NR Hard Drive Replacement, Keyboard: passo 2, imagem 1 %32 HP Mini 110-1046NR Hard Drive Replacement, Keyboard: passo 2, imagem 2 %32
    • With the screen closed, turn your netbook around so that the battery slot is facing you.
    • Remove the three 2.9mm screws in the battery slot.
    • This step can be made easier by using a magnetic screwdriver.
  3. HP Mini 110-1046NR Hard Drive Replacement: passo 3, imagem 1 %32 HP Mini 110-1046NR Hard Drive Replacement: passo 3, imagem 2 %32 HP Mini 110-1046NR Hard Drive Replacement: passo 3, imagem 3 %32
    • Flip the netbook upright, and open the screen as far as it will go.
    • Pry up the keyboard from the middle of the top edge.
    • Insert the flat end of the spudger between middle of the the top edge of the keyboard and the plastic frame behind it.
    • Pry the keyboard up until it pops out or until you can grab it with your fingers, and then pull gently until it pops out on both sides.
    • Do not pull the keyboard out immediately - there is a potentially fragile ribbon cable that attaches to the motherboard behind the keyboard.
  4. HP Mini 110-1046NR Hard Drive Replacement: passo 4, imagem 1 %32 HP Mini 110-1046NR Hard Drive Replacement: passo 4, imagem 2 %32 HP Mini 110-1046NR Hard Drive Replacement: passo 4, imagem 3 %32
    • Flip the keyboard over (toward you) by pivoting it about the lower edge, and lay it upside down on top of the touchpad area to reveal the ribbon cable.
    • Lightly pull up on the black tab on top of the keyboard ribbon cable until it hinges toward you and releases the ribbon cable end.
    • Pull the ribbon cable backward and out of the receptacle. This should not require any effort.
  5. HP Mini 110-1046NR Hard Drive Replacement, Hard Drive: passo 5, imagem 1 %32 HP Mini 110-1046NR Hard Drive Replacement, Hard Drive: passo 5, imagem 2 %32 HP Mini 110-1046NR Hard Drive Replacement, Hard Drive: passo 5, imagem 3 %32
    • Remove the three screws holding down the hard drive. Use a Phillips PH0 screwdriver for the two silver, 3.4mm screws on the right, and use a PH1 for the black, 10.3mm screw on the left.
    • It is not necessary to fully remove the 10.3mm screw, but if you do, be careful to not lose the spring.
  6. HP Mini 110-1046NR Hard Drive Replacement: passo 6, imagem 1 %32 HP Mini 110-1046NR Hard Drive Replacement: passo 6, imagem 2 %32 HP Mini 110-1046NR Hard Drive Replacement: passo 6, imagem 3 %32
    • As shown on the top face of the hard drive itself, pull hard drive left using the black tab until the hard drive is unplugged and entirely released from its receptacle.
    • Lift the hard drive out of the laptop.
    • Place the hard drive in an anti-static bag to reduce the likelihood of damaging it with static electricity.
Conclusão
To install a new hard drive or re-install the old one, follow these instructions in reverse order.
11 outras pessoas executaram este guia.
Amos Hine
Membro desde: 10/18/13
1.257 Reputação
Autoria de 7 guias
Equipe
Clemson, Team 14-1, Benson Fall 2013 Membro de Clemson, Team 14-1, Benson Fall 2013
CLEM-BENSON-F13S14G1
Membros da 3
Autoria de 12 guias
Um comentário
Appreciate the article well Done !!!
jpc6517 - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 16
Últimos 30 dias: 68
Duração total: 22,628
