Ir para o conteúdo principal
HP Mini 110-1046NR Battery Replacement
  1. HP Mini 110-1046NR Battery Replacement, Battery: passo 1, imagem 1 %32 HP Mini 110-1046NR Battery Replacement, Battery: passo 1, imagem 2 %32 HP Mini 110-1046NR Battery Replacement, Battery: passo 1, imagem 3 %32
    • Power-off the netbook fully before attempting to remove the battery.
    • Flip your netbook upside down, and locate the sliding tabs near the battery.
    • Slide both tabs inward so that the battery visibly moves away from the case of the computer.
    • Release the tabs and pull the battery out.
Conclusão
To install a new battery or re-install the one you removed, simply press it into the slot until both tabs snap back to their outward-most position
Amos Hine
Membro desde: 10/18/13
1.275 Reputação
Autoria de 7 guias
Equipe
Clemson, Team 14-1, Benson Fall 2013 Membro de Clemson, Team 14-1, Benson Fall 2013
CLEM-BENSON-F13S14G1
Membros da 3
Autoria de 12 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 15
Duração total: 3,839
