Ir para o conteúdo principal
HP Mini 1000 USB & Power Board Replacement
Pré-requisito somente
Este guia destina-se apenas a ser usado como pré-requisito para outros guias. É incompleto por si só.
O que você precisa
  1. HP Mini 1000 USB & Power Board Replacement, USB & Power Board: passo 1, imagem 1 %32
    • If present, remove the two pieces of tape covering the cables routed near the USB and power board.
  2. HP Mini 1000 USB & Power Board Replacement: passo 2, imagem 1 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Use a pair of tweezers to pull the internal display switch cable straight away from its socket on the USB and power board.
  3. HP Mini 1000 USB & Power Board Replacement: passo 3, imagem 1 %32
    • Peel and de-route the SIM card ribbon cable from its channel on top of the underside of the battery compartment.
    • The SIM card ribbon cable is still connected to the USB and power board. Do not completely remove it yet.
  4. HP Mini 1000 USB & Power Board Replacement: passo 4, imagem 1 %32
    • Remove the single 3 mm Phillips screw that secures the USB and power board as well as the DC jack bracket to the lower case.
  5. HP Mini 1000 USB & Power Board Replacement: passo 5, imagem 1 %32 HP Mini 1000 USB & Power Board Replacement: passo 5, imagem 2 %32
    • Lift the DC jack bracket up off the USB and power board.
  6. HP Mini 1000 USB & Power Board Replacement: passo 6, imagem 1 %32 HP Mini 1000 USB & Power Board Replacement: passo 6, imagem 2 %32
    • Grasp the USB and power board from its left edge, nearest the ports side.
    • Remove the USB and power board straight away from its recess in the lower case, minding any cables that may get tangled.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 5
Duração total: 39
