Ir para o conteúdo principal
HP Mini 1000 PRAM Battery Replacement
O que você precisa
  1. HP Mini 1000 PRAM Battery Replacement, Battery: passo 1, imagem 1 %32 HP Mini 1000 PRAM Battery Replacement, Battery: passo 1, imagem 2 %32
    • With the case closed, place the Mini 1000 top-side down on a flat surface.
    • Push both of the battery release latches toward each other.
  2. HP Mini 1000 PRAM Battery Replacement: passo 2, imagem 1 %32
    • Lift the battery out of the Mini 1000 from the edge closest to the release latches.
    Need a battery and a keyboard.
    valfin.teach - Responder
  3. HP Mini 1000 PRAM Battery Replacement, Keyboard: passo 3, imagem 1 %32
    • Remove the following two screws:
    • One 6 mm Phillips screw
    • One 4 mm Phillips screw
  4. HP Mini 1000 PRAM Battery Replacement: passo 4, imagem 1 %32 HP Mini 1000 PRAM Battery Replacement: passo 4, imagem 2 %32 HP Mini 1000 PRAM Battery Replacement: passo 4, imagem 3 %32
    • To facilitate the removal of the keyboard, it is recommended to push the keyboard outwards with one hand through the opening (highlighted in the third picture) located on the backside of the Mini 1000.
    • While pushing through the opening with one hand, grasp the left upper edge with the other hand and slightly pull the keyboard towards you.
    • Once an opening has been established, grasp the keyboard and slowly lift it upwards along the upper perimeter of the top edge.
  5. HP Mini 1000 PRAM Battery Replacement: passo 5, imagem 1 %32
    • Lift the keyboard out of the upper case, minding the cable that is still connecting it to the motherboard.
  6. HP Mini 1000 PRAM Battery Replacement: passo 6, imagem 1 %32
    • Use your fingernail or the flat end of a spudger to flip up the retaining flap on the keyboard cable ZIF socket.
    • Be sure you are prying up on the retaining flap, not the socket itself.
    • Pull the cable out of its socket and remove the keyboard.
  7. HP Mini 1000 PRAM Battery Replacement, Hard Drive: passo 7, imagem 1 %32 HP Mini 1000 PRAM Battery Replacement, Hard Drive: passo 7, imagem 2 %32
    • Use your fingernail or the flat end of a spudger to flip up the retaining flap on the SIM card ribbon cable ZIF socket.
    • Pull the SIM card ribbon cable out of its socket and peel it off the top of the hard drive enclosure.
  8. HP Mini 1000 PRAM Battery Replacement: passo 8, imagem 1 %32
    • Use your fingernail or the flat end of a spudger to flip up the retaining flap on the hard drive cable ZIF socket.
  9. HP Mini 1000 PRAM Battery Replacement: passo 9, imagem 1 %32
    • Remove the two 4.5 mm Phillips screws securing the hard drive to the lower case.
  10. HP Mini 1000 PRAM Battery Replacement: passo 10, imagem 1 %32 HP Mini 1000 PRAM Battery Replacement: passo 10, imagem 2 %32
    • Lift the hard drive up and out of the lower case, being careful not to damage its cable in the process.
  11. HP Mini 1000 PRAM Battery Replacement, Upper Case: passo 11, imagem 1 %32
    • Using the sharp tip of a spudger, pry and remove the four plastic screw covers from the underside of the HP Mini 1000.
    • There are three different variations of the covers:
    • The two bottom covers are short in height and are notched to prevent incorrect insertion
    • The upper right cover is taller in height and is notched.
    • The upper left cover is taller in height and is not notched.
  12. HP Mini 1000 PRAM Battery Replacement: passo 12, imagem 1 %32
    • Remove the four 7 mm Phillips screws that secure the upper case to the lower case.
  13. HP Mini 1000 PRAM Battery Replacement: passo 13, imagem 1 %32
    • Flip the computer over and open the display.
    • Remove the two 4.5 mm Phillips screws securing the upper case to the lower case.
  14. HP Mini 1000 PRAM Battery Replacement: passo 14, imagem 1 %32 HP Mini 1000 PRAM Battery Replacement: passo 14, imagem 2 %32
    • Wedge the flat end of a spudger in between the upper case and lower case near the bottom right corner of the display.
    • Carefully pry and rock the spudger upwards to create a small gap between the upper case and lower case.
    • Continue the previously described motion along the right edge of the upper case to release the clips securing the upper case to the lower case.
  15. HP Mini 1000 PRAM Battery Replacement: passo 15, imagem 1 %32 HP Mini 1000 PRAM Battery Replacement: passo 15, imagem 2 %32
    • Repeat the same procedure as mentioned in the previous step to release the clips along the left side of the upper case.
  16. HP Mini 1000 PRAM Battery Replacement: passo 16, imagem 1 %32
    • Grasp the upper case and carefully lift it slightly upwards, freeing it from any remaining clips.
    • The upper case is still attached via the TouchPad ribbon cable that is connected to the motherboard. Do not remove it completely just yet.
  17. HP Mini 1000 PRAM Battery Replacement: passo 17, imagem 1 %32
    • Lay the upper case on top of the upper portion of the motherboard.
    • Use your fingernail or the flat end of a spudger to flip up the retaining flap on the TouchPad cable ZIF socket.
    • Pull the TouchPad ribbon cable out of its socket.
    • Remove the upper case from the HP Mini 1000.
  18. HP Mini 1000 PRAM Battery Replacement, PRAM Battery: passo 18, imagem 1 %32
    • If present, carefully peel back the large piece of black film attached to the heat sink to reveal the PRAM battery and its connector.
    • It is not necessary to completely remove this film.
  19. HP Mini 1000 PRAM Battery Replacement: passo 19, imagem 1 %32 HP Mini 1000 PRAM Battery Replacement: passo 19, imagem 2 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Use a pair of tweezers to pull the PRAM battery connector out of its socket.
    • Pull the connector parallel to the face of the motherboard toward the fan side of the computer.
    • Use the flat end of a spudger to pry the PRAM battery off the adhesive securing it to the motherboard.
    • Remove the PRAM battery.
Conclusão
3 outras pessoas executaram este guia.
4 comentários
Where can you find the replacement battery for this? do you take it apart and slide in a cr2016 watch battery?
Jake Stitt - Responder
Try eBay. If you can solder, it's best to get a CR1616 with tabs
The Eminent Joshua E. Hrouda -
whhere cann youu findd a replacement bbattery in 2018
Κωνσταντίνος Σακελλαρόπουλος - Responder
Is there enough room to install a CR2020 or a CR2025?
The Eminent Joshua E. Hrouda - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 18
Duração total: 3,844
