Ir para o conteúdo principal
HP Media Center 876x Front Cover Replacement
O que você precisa
  1. HP Media Center 876x Front Cover Replacement, Side Panel: passo 1, imagem 1 %32 HP Media Center 876x Front Cover Replacement, Side Panel: passo 1, imagem 2 %32
    • Remove the two (9 mm) hand screws on the back panel.
  2. HP Media Center 876x Front Cover Replacement: passo 2, imagem 1 %32 HP Media Center 876x Front Cover Replacement: passo 2, imagem 2 %32 HP Media Center 876x Front Cover Replacement: passo 2, imagem 3 %32
    • Place the tower on its side.
    • Slide the side panel horizontally to detach, and pull upward to remove.
  3. HP Media Center 876x Front Cover Replacement, Front Cover: passo 3, imagem 1 %32 HP Media Center 876x Front Cover Replacement, Front Cover: passo 3, imagem 2 %32
    • Orient the tower vertically.
    • Using the #0 Phillips head screwdriver, unscrew and remove the two (5 mm) screws that fasten the remaining side panel to the tower.
    • Slide the side panel out of its notches, and pull it gently off of the tower.
  4. HP Media Center 876x Front Cover Replacement: passo 4, imagem 1 %32
    • Gently move the tower so that it is in the horizontal orientation.
    • Press down the black tabs (proximal to you) that fasten the front panel to the tower.
    • Press down on the distal, black tabs (symmetric with respect to the previous tabs).
    • Pull front panel forward slightly.
  5. HP Media Center 876x Front Cover Replacement: passo 5, imagem 1 %32 HP Media Center 876x Front Cover Replacement: passo 5, imagem 2 %32
    • The front panel will come off in a hinge-like fashion, exposing the drives underneath.
Conclusão
Equipe
Clemson, Team 6-1, Benson Spring 2014 Membro de Clemson, Team 6-1, Benson Spring 2014
CLEM-BENSON-S14S6G1
Membros da 3
Autoria de 15 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 2
Duração total: 403
